ZeroCentre Fanuc alarm 960
Any information regarding the Denford ZeroCentre ZeroTurn ZeroBore Fanuc CNC machines
just-cut-it!
Hardware/Software: Zerocentre
Orac
Post by just-cut-it! » Sun 05 Jan , 2020 23:01 pm
I am in process of rebuilding a zerocentre, machine number 8 I believe with Fanuc OMb. The mc has been powered down for about 2 years and I have just tried to bring her back to life following major mechanical overhaul. When the mc starts it displays error 960 non masked interrupt. This error code is not listed in the Fanuc manual. All the psu voltages measure as they should. All advice welcome.
Re: ZeroCentre Fanuc alarm 960
Post by Martin » Mon 06 Jan , 2020 9:28 am
Fanuc Alarm 960 DC24V POWER OFF
just-cut-it!
Orac
Post by just-cut-it! » Thu 09 Jan , 2020 23:31 pm
I’ve double checked all the power supply lines on the main board
including the +24v and they all look good. Service exchange main board is £1400 +VAT need less to say I would really like to avoid this if at all possible. Any suggestions gratefully received.
DavidB
Post by DavidB » Fri 10 Jan , 2020 2:19 am
I don't know this machine or electronics but for an initial check I would look out for any socketed chips and after grounding yourself I would prise the chips out and press them back in. Classic failure in old electronics with tinned leads is oxide film formation causing degradation of the signals and removing and re-installing the chips wipes the oxide and restores signal.
just-cut-it!
Orac
Post by just-cut-it! » Tue 25 Feb , 2020 22:25 pm
Just a quick update and for the benefit of anyone who is experiencing similar problems (alarm 960, 910, 911, 930) The fix was to desolder and replace the two SRAM chips (type 43256) these are still available new and only cost a few pounds.
The control now boots as it should so it’s just a case of entering in all the parameters and hopefully it’ll be making chips again soon🤞
madmaxpl
Hardware/Software: HAAS VF-4 - Fanuc
HAAS VF-2 - Fanuc
MORI SEIKI ZL15-S - Fanuc 0-TT
Post by madmaxpl » Thu 03 Feb , 2022 11:08 am
I have a similar problem on my lathe Mori seiki ZL-15-S. fanuc 0-TT control. I removed the plate and gave it to the electronics for checking. According to him, SRAM 43256 is ok. There is no need to replace it.
was it similar in your case too?
