Pause opening or closing door
All info relating to the Denford VMC1300 and VMC1300 Pro CNC milling machines
Ansel
Hardware/Software: VMC 1300 PRO
QUICK CAM 2D
VR MILLING V5
QUICK CAM PRO
Post by Ansel » Fri 12 Apr , 2019 18:47 pm
I have a problem opening and closing the door. When I send the command M38 and M39 there is a delay to make the function. You need to press the Esc key to continue opening or closing the door, as it remains paused. I do not know if it is the PC communication with the CNC. I change to the PC but the problem continues. Any ideas.
I have a VMC 1300 Pro.
Thank you for the help.
