METRIC Viceroy TDS 1/1 GBL - IMPERIAL SCREWCUTTING?
jpopowski
Post by jpopowski » Thu 17 Jul , 2014 10:32 am
I hope that somebody can answer this question!
I have a METRIC Viceroy TDS 1/1 GBL centre lathe.
I have done much research and it seems that this machine cannot be set-up to cut Imperial threads.
Am I correct with this conclusion?
My setup is as shown in my recent post regarding metric screw-cutting procedure on this machine. I am currently in possession of all the gears for an Imperial machine, including a 127T gear, but nothing is at all compatible.
So, is a metric machine capable of being easily setup to screw-cut imperial threads?
Somebody please enlighten me!
LesT
A WMD25V mini mill.
Re: METRIC Viceroy TDS 1/1 GBL - IMPERIAL SCREWCUTTING?
Post by LesT » Thu 17 Jul , 2014 20:45 pm
There was a discussion about this a while ago. Here is a link.
viewtopic.php?t=1061
(Have a look at the XL spreadsheet)
The answer is no, it can't exactly. But if you follow the instructions in the XL spreadsheet you can cut a thread that
will work satisfactorily within limits. If you want to cut a (say) 200mm long imperial thread, to fit a long tapped hole, you won't be able to do it, but a short thread is fine. I've done this and it works OK.
Les.T.
