my new lathe an old viceroy
Dougiealan
Hardware/Software: Viceroy tds 1.1
Re: my new lathe an old viceroy
Post by Dougiealan » Thu 06 Feb , 2014 11:33 am
Hi Jeff, nice machine for £300 mine hasn't got the gear box like yours has and I paid double that with only a 3 jaw chuck. I noticed you are VFD I seen a teco 1hp inverter on ebay for £110 do you know if this will do for my machine? it has a 3 phase motor and I'd like to control the speed with out changing belts and pulleys. The people I bought it from said its a duel voltage motor that's on it and said I'd need a convertor electrics aren't my strong point and don't want to buy unless I'm 100% sure. I bought a 1hp single phase motor to get me running until I get a better understanding on how to go about the invertor/convertor and firing the 3 phase one back in.
Regards Alan.
jeff1137
Post by jeff1137 » Thu 06 Feb , 2014 11:35 am
The TDI I got is off the Mk 1 lathe & I have the Mk2.
Does anyone know if there is a difference or modification to the TDI for the Mk 2 T.D.S.1/1. & the Mk1 .
Looking at them the only thing I can see is the spacer on the Mk2.
On the Mk1 the TDI fits next to the lathe & on the Mk2 the is a small spacer Ml109/5 11/16” bush.
Does the bush make any difference to the running of the lathe, I cannot see that it would, but you never know.
Jeff
Thank you for the advice, it is all ways welcome.
jeff1137
Post by jeff1137 » Thu 06 Feb , 2014 11:40 am
Hi Alan
Please ring me I have sent you a PM
Jeff
dazz
Post by dazz » Fri 07 Feb , 2014 0:10 am
jeff1137 wrote:Hi dazz
I will program the VFD presently, how long did you give the motor to slow down & stop & run up,
About 4 seconds
jeff1137 wrote: did you fit a brake to the VFD.
No definitely not. The risk is that stopping too quickly will cause the chuck to unwind off the spindle.
jeff1137 wrote: What size motor did you fit.
1.2kW
jeff1137 wrote: Did you first fit a DC motor to the lathe
No
jeff1137 wrote: I have a 900w motor 3ph, have you had any prolemes runing at 1800 rpm, my motor is old maybe 15-25 years ???
For that size motor, I would recommend a max of about 1500rpm.
It doesn't really matter because you can increase torque by engaging the backgear.
Dazz
jeff1137
Post by jeff1137 » Fri 07 Feb , 2014 0:27 am
About 4 seconds
Hi Dass
is that 2s up & 2s down, of 4s up & 4s down.
thanks jeff
Jeff
dazz
Post by dazz » Fri 07 Feb , 2014 0:40 am
That's 4s up and 4s down.
My VFD achieves this by ramping the speed. There is no brake resistor.
Dazz
jeff1137
Post by jeff1137 » Fri 07 Feb , 2014 1:47 am
dazz wrote:Hi
Hi Dazz
Thanks, it will make it easier to program the VFD if i know it will work right first time.
Jeff
