I decided to start a custom motorcycle building company, but i decided that i'd try make a few things as a hobby to find out what i needed to learn before making it into a proper business. So, i bought myself a bunch of tools and made myself a motorcycle frame using some pre-made parts etc and going to local machinists to get them to make up jig parts etc etc, then my mate, who's a professional welder finished welding up the first frame that i made.
After that i decided that i'd much rather be able to make all the parts that i need at home. For that i'd need to learn to be able to weld correctly (so i went to college and done two courses) and use a lathe...then buy one.
Thankfully along the way i befriended a machine shop owner and he started teaching me the basics of using a lathe, and in return i done bits 'n bobs for him around the shop. So after i thought i knew the basics i looked into buying my 1st lathe.
I sold one of my motorbikes and bought this little beasty from a friend of my father-in-law.
![Image](http://i60.tinypic.com/igg4gk.jpg)
The first problem i ran into was that the person who owned it before me changed it from 3 phase to single phase and wired it up so that i only turned in one direction (great thing for a screw cutting lathe right!?). I now have it working in both directions with the single phase motor.
I also realised that the lathe i'd learned the basics on had a quick change tool post and mine doesn't, so i learned pretty quickly how to shim tools to the correct height after breaking one or two tools!
So my questions after all that waffle are;
1. where could i get a quick change tool post and what type am i looking for? is a generic boxford one from eBay going to be ok?
2. how do i remove the lathe chuck? as i have a couple of other ones i'd like to try on it (i have two, three jaw chucks and a four jaw chuck)
3. what type of coolant do you think i should run? i'm mainly going to be turning bright steel and a little bit of aluminium. I'm thinking of putting a coolant pump in and having a feed going to the work piece, as i've used this kind of set up on my friends lathe and it worked very well.
4. where should i be greasing up/oiling to ensure my lathe runs smoothly and i don't accidentally wear parts out?
5. how do i centre the tailstock? i managed to drill a hole in a piece that i turned and it was slightly off centre.
6. how do i use the gearbox correctly? i have the document that someone made up for it (so that should cover most of it) but the leadscrew/feedshaft only appears to turn when i have it on specific settings...that appear to be completely off from what the document that i've read advises. i.e. rotary selector dial at 3 and the gear engagement lever at 1. I haven't yet changed any of the spur gears, is that one of the reasons?
At the moment i'd like to have the lathe not trying to cut threads, just a nice even surface (what is the best setting for that so that i can turn the leadscrew on and let the machine work it's way up the work piece rather than me do it all by hand?).
I hope this isn't too long for you all (and posted in the correct area of the forum!)
Any and all help is welcomed.
Thanks in advance!
Alastair
