Can this cut plastikard, sheet syrene, polystyrene?
can this machine cut sheet styrene? (as in, polystyrene)
I am sure it will cut styrene. It depends on the thicknes and finish you want. I have cut 25mm polystyrene and while the top surface is OK the back has melted away.
If you want to send us a sample of the material and what you want to cut we could have a go for you.
If you are in the area you could arrange to call in and have a go.
You cannot cut PVC as chlorine gas would be given off.
