Versa Laser fume extraction not working
Post by bradders » Thu 23 Feb , 2006 11:40 am
Versa Laser fume extraction not working and smoke is filling the working area
Replace the 5 Amp fuses with 6.3 Amp "time lag" (Slo-Blo) fuses.
Note ! On the bottom right hand side of the back of the Versalaser (when viewed from the rear) there is a kettle plug socket built into the fan unit. Remove the kettle plug and to the right of the socket is the fuse holder.
Press both tabs towards each other and pull out the fuse holder, check with an electrical meter to see if the fuse/s have blown and replace with 6.3 Amp "time lag" (Slo-Blo) fuses.
