Laser is not penetrating the material as good as it used to
Post by bradders » Thu 06 Jul , 2006 13:18 pm
The Laser beam is not penetrating the material as good as it used to ?
Post by bradders » Thu 06 Jul , 2006 13:21 pm
Read the Laser manual for mirror and lens cleaning procedures
1. Ensure the Mirrors are clean
2. Ensure the Lens is clean
3. Ensure the Window on the Laser cartridge is clean
4. Remove any deposits from the nozzle of the air assist cone
Post by Martin » Thu 05 Oct , 2006 19:12 pm
Yon may also need to check the focus height. This can be done by using the manual focus tool as described in the VersaLaser manual.
Post by Martin » Fri 06 Oct , 2006 1:08 am
Focusing the laser beam
Doc1.doc
(126 KiB) Downloaded 787 times
Auto-Z & Rotary Calibration
Post by Martin » Fri 05 Jan , 2007 16:25 pm
The Versalaser CPU holds all the positions & can be reset with the guide attached.
The flat metalic bed needs to be used when setting the heights.
A020 - CPU Initialization Auto Z and Rotary Calibration.pdf
(242.02 KiB) Downloaded 734 times
