Cutting Ok on the RHS of the machine but not on the LHS
- bradders
My Laser is cutting Ok on the RHS of the machine but not on the LHS. Any idea's ?
- bradders
If the fault not been cured with the levelling up of the bed, then with the symptoms you mentioned, i.e. Cutting Ok on the RHS of the machine but not on the LHS, we think it could be the lens that is damaged. Can you visually inspect the lens and see if you can see any abnormalities i.e. Blackening, Cloudiness, surface build you of debris etc. If so you could try cleaning the surface with Acetone
- Triac whizz
sounds like an alignment issue
nozzle offset from the laser beam - given it a clout have we?
www.la-coterie.com
www.la-coterie.com
- Triac whizz
I dunno if you can do this with your machines but we used to the following with the industrial stuff..
sellotape over the nozzle, mark the side facing you then fire a quick low level beam. That obviously zaps a hole in the sellotape. Take the nozzle off and check concentricity of the hole with a loupe. If it's not central give it a wallop
but, yeah, perhaps the lense is sh*gged, sorry I mean dirty
www.la-coterie.com
www.la-coterie.com
Beam Alignment
IT sounds like a beam alignment issue, a tube issue or a table level issue.
Measure the parallelity from the carriage to the aluminum bed with the focus tool in all 4 corners and see if there is a diffference. If yes, then align the table!
best regards
Bernhard
Bernhard
