turret problem in 270 pro
All info relating to the Denford Turn270 and NewTurn270 CNC lathes
mfawzy
Hardware/Software: vr turning
Post by mfawzy » Sat 25 Jan , 2020 8:47 am
dear there ,
i have 270 pro machine ,when i select a tool i find it is not stopping in the same position every time
if i select tool 1 ,i find it shifting from the tool home position
this shift is accumulated every time i select the tool
this makes the tool can not reach the surface of the billet
any one can help ?
thanks very much
Re: turret problem in 270 pro
Post by Martin » Mon 27 Jan , 2020 8:36 am
It may be worth checking the motor coupling. You should be able to remove the four cap head screws & pull the motor out. Depending on the age it will either have a Oldham Coupling or a split pin.
mfawzy
Post by mfawzy » Thu 30 Jan , 2020 16:31 pm
i checked the motor coupling , it is no problem
i checked the 2 limit switches on the other side from the turret
i seems the problem is the round cam activating the limit switches
the cam is contentiously pressing on the zero point limit switch , i will reduce the diameter of the cam and check again the result
Post by Martin » Fri 31 Jan , 2020 8:30 am
The 2 microswitches are mounted on a plate that is movable. It`s fastened on with 3 cap head screws.
mfawzy
Post by mfawzy » Sun 16 Feb , 2020 18:15 pm
thanks very much for your reply
i did the same , and now machine is running Ok
i found a new problem where the machine is not executing the thread
i don't know why ?
Post by Martin » Mon 17 Feb , 2020 8:33 am
DO you get a spindle speed readout?
