machining a large model
Posted: Thu 31 Jan , 2019 9:58 am
by pdickinson
Morning All,
I am currently using the 2600 PRO to manufacture some sixth form projects, but I am having a problem with the amount of waste material produced during the process. Is there a way of stopping the machine mid cycle so that I can remove the waste and then resume it? I am sure our old technician had a way of doing this, but the knowledge went with him...
Re: machining a large model
Posted: Fri 01 Feb , 2019 9:53 am
You can stop the program at any point & then use specify a start block using the icon on the bottom left.
The icon has a picture of a magnifying glass in it & the line you stopped at should be present.
Posted: Fri 01 Feb , 2019 13:41 pm
by pdickinson
:lolol:
Thank you! worked perfectly!
