Denford Software & Machines
Welcome to the Denford CAD CAM CNC forum
Hint - Try the google search at the bottom of the page
It is currently Sun 27 May , 2018 20:29 pm
Post new topic Reply to topic  [ 4 posts ]
Author Message
 Post subject: Not stopping and homing after a job
PostPosted: Fri 19 May , 2017 3:29 am
Offline
Posts: 10 Hardware/Software: Router 2600
My machine is cutting fine but after a job it stops at the end, router still spinning and does not home. I am having to do this manually. I'm sure it's something simple - any clues?
Thanks in advance
Top
 Profile
 Post subject: Re: Not stopping and homing after a job
PostPosted: Fri 19 May , 2017 23:24 pm
Offline
Posts: 310 Hardware/Software: Starturn 5 (sort of running, I will get this done!)
Roland CAMM3 PNC3000 (For Sale)
Check the G code. Are the lines there to stop the spindle and home? if not its not the machine but how the code is being written
Top
 Profile
PostPosted: Sat 20 May , 2017 7:36 am
Offline
How are you stopping the spindle at the end? Can you just enter jog mode?
It could be the communications have failed down the USB. What are you machining and are you running the extraction?
Is so try running without the extraction. It could be a static problem.
Top
 Profile
PostPosted: Sun 21 May , 2017 3:05 am
Offline
Worked fine today! Weird. I think a connection issue...
Thanks guys
Top
 Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 1 guest
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
Template made by DEVPPL
[ Time : 0.145s | 19 Queries | GZIP : Off ]
Loading
