I'm sure this information is out there somewhere, but I can't find it, and I'm trying to avoid taking my lathe apart to count timing pulley teeth, so... Can anyone tell me what the pitch of the two lead screws is, and what the ratios are on the standard pulleys (for both axes)?
Thanks!
-Luke
Lead screw pitch and pulley ratios
Re: Lead screw pitch and pulley ratios
Hi Luke,
Z is 5mm Pitch, and on my machine pulley ratio is 1:1.75
X is 2.5mm Pitch with 1:1.25 ratio
couldn't tell you if standard though
