I am trying to fix an Orac that has a large backlash on the Y axis. A dial indicator showed at least 0.010" of lash and it can be seen moving just by grabbing the compound and pushing/pulling it along the Y axis.
After disassembly and wiping away the old grease/oil, and reassembling, the lash is apparently gone but the screw feels a bit tight. No numbers but I was unable to turn it by hand without the timing belt pulley installed. With the pulley installed, I can turn it and move the slide but it feels tight. I applied oil to parts of the thrust assembly prior to reassembly if this makes a difference.
Question is how tight should the thrust bearing on the Y axis be set? I don't seem to have much flexibility there due to the start/castle nut/washer locking
mechanism. I also didn't see anything apparently wrong with the thrust
bearings inside the assembly.
Orac Y axis thrust bearing preload
Jump to
- Welcome
- ↳ Announcements
- CNC / Machines
- ↳ Machines
- ↳ Compact 1000
- ↳ Cyclone
- ↳ EasiMill / EasiTurn
- ↳ Meteor
- ↳ Micromill / Microturn
- ↳ MicroRouter
- ↳ MicroRouter Compact
- ↳ Mirac
- ↳ Novamill
- ↳ NovaTurn
- ↳ Orac
- ↳ PCB Engraver
- ↳ Quatro
- ↳ Router 2600
- ↳ Senior (Tom)
- ↳ StarMill
- ↳ StarTurn
- ↳ Triac
- ↳ Triton
- ↳ Turn270
- ↳ VersaLaser
- ↳ Viceroy
- ↳ VMC 1300
- ↳ Electronics
- ↳ Software
- ↳ Downloads
- CAD / CAM Software
- ↳ QuickCAM 3D/PRO/4D
- ↳ QuickTURN 2D Design
- ↳ TechSoft 2D Design
- ↳ Post Processors
- ↳ Solidworks
- ↳ VR Milling - All Versions
- ↳ VR Turning - All Versions
- ↳ Other CAD CAM and CNC
- ↳ UP! 3D Printer
- General
- ↳ Project Of The Week
- ↳ Denford Classifieds
- ↳ F1 / 4x4 / GT Racing In Schools
- ↳ Suggestions and Feedback
- CIM
- ↳ Robots / CIM / VR CIM
- Random Picture Galleries
- ↳ Vintage Pictures
