Orac tool changer problem
The tool changer will not stop. As soon as you turn on the machine it starts rotating though the tools. Any sugestion on how to fix. All the wires seem to be connected and the dead man switch is not stuck.
It was working but now it just turns constant and doesnt reverse to stall out. The dead man doesnt do anything its dead. It use to activate the tool changer to the next tool then rev. and stall out. Its turning slow as if to change tools and is going in the correct direction.
At the same time in manual mode when i turn on the spindal it revs up to max rpm then goes back to 370 on its own. The speed control buttons are not working at all.
Every thing was working fine last week. Starting to think I have a short some where.
