Feedrate Override
dixonsca
Hardware/Software: Denford Magnum router. (now upgraded to a 3d router using retrofit kit macmotion controller and upgraded stepper motors)
Triac PC
Nova mill
Microrouter
Turn 270 Pro
Unimatic 4th axis
Makerbot Replicator 2
VR Milling 5
techsoft 2d design
corel draw
solidworks
artcam
lathecam designer
quickturn 2d
Feedrate Override
Post by dixonsca » Fri 12 Jul , 2019 9:06 am
Hi all.
I connect and can home the novamill but as soon as I try jog this pops up. The pots are inactive so cant just turn them up. Can anybody shed any light on it, I must just be overlooking something dead simple?
FR overide1.jpg (20.48 KiB) Viewed 7373 times
Re: Feedrate Override
Post by Martin » Fri 12 Jul , 2019 12:06 pm
Does your Novamill have the override pots fitted? They should be on the front next to the Emergency Stop Button.
If you don't have them you can turn the option off in the software.
Goe to Setup then Setup Machine Parameters(Password is denny) then under Novamill go to Machine Capability then untick both Feed & Speed override options. When you exit it will save the values.
dixonsca
Triac PC
Nova mill
Microrouter
Turn 270 Pro
Unimatic 4th axis
VR Milling 5
techsoft 2d design
corel draw
solidworks
artcam
lathecam designer
quickturn 2d
Post by dixonsca » Fri 12 Jul , 2019 12:30 pm
No it doesn't have the physical pots on the machine. Will check the parameters. Thank you.
