Pausing between blocks
dhop125
Hardware/Software: Mirac PC with VR turning
Boxford Duo with Mach 3
Post by dhop125 » Wed 08 Apr , 2020 20:58 pm
My mirac pc pauses between each block of code.
For example, if the program was to read:
N010 G01 X15 Z0
N015 G01 X15 Z-5
N020 G01 X15 Z-20
Then the feed would pause for a considerable time at Z-5 leaving a gouge in the workpiece as it chatters.
( I know you would not normally use such a code as above but it's just for illustration)
I have seen this issue before in milling, where the solution was to use G64. But the miracle doesn't recognise it.
I believe it is a denstep board but can't be sure, I'm not able to get access to the box to check.
Anyone come across this before?
www.clydepencompany.com
Re: Pausing between blocks
Post by Steve » Thu 09 Apr , 2020 19:04 pm
What version of software are you using?
Have you got turbo turned on on the control panel?
dhop125
Post by dhop125 » Thu 09 Apr , 2020 20:22 pm
Software is VR turning v1.49.0.0
Sorry, I'm new to vr turning! you'll have to point me in the direction of the control panel...
Do you mean machine parameters? There's a check box for high speed cutting under "machine capability"?
Duncan
