View unanswered posts | View active topics
| Author |
Message |
CHudson
Post subject: Denford Mirac Electronics Refurbishment Posted: Tue 09 Mar , 2010 22:42 pm |
Hi Guys, I'll start with a little back ground as this is my first post here! I purchased a new RoutoutCNC CNC router at the end of 2009 with a view to milling PCBs for production of lighting control gear and after allot of mistakes begen producing decent PCBs. I then sat down and created full 3d drawings in Autocad for the actual light fittings and sent those drawings to various cnc machine shops. After getting several ridiculous quotes (£800 + for a garden light fitting) I decided to give it ago myself. My light design is 86mm in diameter so I ideally needed at least 100mm to allow for any play. I looked at various different lathes and kept my eye out on various used machine sites and ebay of course and eventually decided I wanted either a Denford or Boxford Lathe as both seem to have extremely high quality components and generally come with little use as they are often used in schools. I eventually came across a Denford Mirac in near perfect condition. The ball screws and ways are like new and its seems to have only ever machined small plastic parts. It was also a steal at £875.00 excl VAT and in fully working order. The problem is that the electronics in this lathe only work with DOS software and it seems plenty of Mirac owners out there have tried to get the existing electronics to work with windows without any success (providing their machine is pre 1994) leaving the only route of converting with new drives to work with Mach3 or similar. The new drives are probably going to be the easy bit. The hard bit is going to be getting the automatic tool changer to work and spindle controls. There seems to be at least 2 people out there that have successfully done a conversion but unfortunately have not posted a build log so its hard to work what they have done to get their machines to work. Anyway on with the build: I have so far purchased 2 Gecko 201x Drives and also the C11G breakout board from CNC4PC. I will be posting pictures and more information very soon. I have also posted this thread on http://www.cnczone.com/forums/showth...300#post746300 and on http://www.mycncuk.com/forums/showthrea ... nt&p=11615
| Top |
CHudson
Post subject: Re: Denford Mirac Electronics Refurbishment Posted: Tue 09 Mar , 2010 23:09 pm |
Heres a wiring schematic for the Denford Mirac thanks to the Denford Admin
| Top |
Post subject: Re: Denford Mirac Electronics Refurbishment Posted: Wed 10 Mar , 2010 10:34 am |
| Site Admin |
Joined: Fri 10 Feb , 2006 12:40 pm Posts: 2125 Location: Sunny Brighouse Hardware/Software: Go to User Control Panel > Profile Enter as much information about your CNC hardware and software as you can - it makes it easier for everyone to know what you're talking about then.
Thanks for sharing... Quote: There seems to be at least 2 people out there that have successfully done a conversion but unfortunately have not posted a build log so its hard to work what they have done to get their machines to work. Unfortunately it seems that most people are keen to post during a conversion or upgrade, but once their machine is up and running you never hear from them again - presumably they're too busy making things! If you think there are members here with valuable information, don't hesitate to send them a PM to give them a nudge
| Top |
CHudson
Post subject: Re: Denford Mirac Electronics Refurbishment Posted: Wed 10 Mar , 2010 19:25 pm |
| Top |
Post subject: Re: Denford Mirac Electronics Refurbishment Posted: Thu 11 Mar , 2010 9:55 am |
| Site Admin |
Quote: The problem is that the electronics in this lathe only work with DOS software I'm not sure about that - I thought the Miracs would have all been be Baldor control based ? We should be able to tell if you post a pic of the control cabinet and control card(s)
| Top |
Post subject: Re: Denford Mirac Electronics Refurbishment Posted: Thu 11 Mar , 2010 18:04 pm |
| CNC Guru |
Joined: Fri 24 Feb , 2006 17:09 pm Posts: 515 Location: Brighouse
We used to fit a GSM LCB3 card. Not sure when we changed over to the Baldor.
| Top |
CHudson
Post subject: Re: Denford Mirac Electronics Refurbishment Posted: Thu 11 Mar , 2010 21:25 pm |
The control card is an LCB3 and doesn't have any of the Euro control bits and pieces. Either way I wanted it to run on Mach3 as its something im familiar with.
| Top |
CHudson
Post subject: Re: Denford Mirac Electronics Refurbishment Posted: Fri 12 Mar , 2010 22:15 pm |
| Top |
Post subject: Re: Denford Mirac Electronics Refurbishment Posted: Mon 15 Mar , 2010 9:45 am |
| Site Admin |
Quote: Does anyone happen to know what cables go to what on these steppers. If not can I just work it out by doing a continuity test? Yes you should find two pairs of wires with the same low resistance reading. I'd guess looking at the photos that if you take the wires off the orange connectors from left to right, you'll have your pairs 1+2;3+4 which will go to 3+4; 5+6 of the Gecko
| Top |
CHudson
Post subject: Re: Denford Mirac Electronics Refurbishment Posted: Wed 17 Mar , 2010 16:27 pm |
I have made a little progress with the machine today. I worked out that I really needed heat sinks and fans for the Geckos as per the manufactures instructions for currents over 3A. I was told a little while ago that the steppers on the Mirac draw 3.5A under load (I also found out they run at 38V). I purchased 2 of these http://uk.rs-online.com/web/search/sear ... &R=158-556 heat sink and fan assemblies and have fitted them to the Geckos. I removed the slave board and then mounted the heat sinks to the large plate of aluminium where the slave board was. I had to order 5 C15 Dual Relay boards from CNC4PC. They will be used for enabling the spindle and tool post, running the spindle and tool post in forward or reverse etc It seems that the spindle and tool post are powered from the motor controller/inverter together and 24V relays are required to turn the contactors off and on to turn the motors off and on. Theres speed control and an encoder for the spindle but doesn't seem to be anything for the tool post other than a DC brake. I'm guessing that the tool post uses a worm drive and runs at a set speed and you just have to time how long you run the motor to get to each tool. I'll post some pictures later on.
| Top |
Post subject: Re: Denford Mirac Electronics Refurbishment Posted: Wed 17 Mar , 2010 17:17 pm |
| Site Admin |
I get confused about all the different turret types we've fitted, but if its the one I'm thinking of, you just need to run it forward until you see the position after the one you want, plus the strobe signal , then reverse the motor and it should lock up in the position you wanted. This would be the one with a 3-bit, greycode input pattern: 7,3,2,0,1,5,4,6 eg: 111 = pos. 1 011 = 2 010 = 3 000 = 4 001 = 5 101 = 6 100 = 7 110 = 8
Some of the older lathes/other turrets had a dedicated toolpost logic board as the control wasn't quick enough to monitor the tool position inputs+strobe and switch the motor direction in time.
| Top |
Post subject: Re: Denford Mirac Electronics Refurbishment Posted: Wed 17 Mar , 2010 19:09 pm |
| CNC Guru |
There is no stobe on the DM8 toolpost you have.
1 x Rotary 8 position switch. 1 x Toolpost clamp switch.
| Top |
CHudson
Post subject: Re: Denford Mirac Electronics Refurbishment Posted: Wed 17 Mar , 2010 19:16 pm |
So where would you normally send the input signals to etc Has it anything to do with the diode module?
| Top |
Post subject: Re: Denford Mirac Electronics Refurbishment Posted: Wed 17 Mar , 2010 21:49 pm |
| CNC Guru |
Yes. The signal from the 8 position rotary switch go to the diode module which alters the signal to a binary greycode as posted by Admin
| Top |
CHudson
Post subject: Re: Denford Mirac Electronics Refurbishment Posted: Fri 19 Mar , 2010 23:07 pm |
| Top |
CHudson
Post subject: Re: Denford Mirac Electronics Refurbishment Posted: Tue 27 Apr , 2010 16:42 pm |
Hi Guys, Sorry its been ages since I've last updated. I've been stuck twiddling my thumbs a little as I am constantly waiting for bits to turn up.
I wired up most the machine. I've managed to get both axis's working, the spindle turning and the tool post turning.
The Control card from CNC4PC is very limited in terms of inputs. I have had to purchase a further Parallel post card and breakoutboard to connect the home and limit switches to.
I'm struggling to get the spindle to turn at the desired speed. It seems to just stay to one constant speed even when using the mach3 tuning tool. I am also struggling to work out which core on the encoder goes to what, i.e are they pairs do they need 5V and Gnd etc
With regards to the tool post, that bit seems to be rather simple, all you need to do is tell mach3 to watch the grey code for the correct tool then stop and reverse then switch back over to the spindle. No voltage need to be applied once is fully locked in, though it wouldn't be possible to apply any constantly anyway as you can only have either the tool post on or the spindle on at any one time.
Oh and does anyone know how many steps per inch or whatever it is?
One final thing, any CAM recommendations?
| Attachments: |
| Top |
Post subject: Re: Denford Mirac Electronics Refurbishment Posted: Wed 28 Apr , 2010 8:52 am |
| Site Admin |
Quote: Oh and does anyone know how many steps per inch or whatever it is? Steps per mm on the original was 200 per mm - for a 400 step/rev stepper. So, if your microstepping the motors with the Geckos, then it will be a multiple of that, I'm guessing at values of 200,400,800,1600 or 2000 steps per mm Encoder wires are normally thicker for the 0v and 5v and twisted pairs for the Signal and Not Signal (A and A; B and B; Z and Z)
| Top |
CHudson
Post subject: Re: Denford Mirac Electronics Refurbishment Posted: Sun 09 May , 2010 12:33 pm |
I'm still strugeling to get the speed control and encoder to work properley. I have found out the following information on the encoder:
Its made by British Encoders, Model 733 DEN and its 60PPR. The cable layout is as follows: Blue Channel A Yellow Channel Z Red +5V Green Channel A
I assume A channel is for direction and Z channel is for RPM count. Any ideas how to set this up in MACH3?
The anologue signal I'm using for the speed control doesnt seem to be changing at present. Not sure if its a software or hardware problem as of yet.
| Top |
Post subject: Re: Denford Mirac Electronics Refurbishment Posted: Mon 10 May , 2010 8:53 am |
| Site Admin |
Quote: I assume A channel is for direction and Z channel is for RPM count. A channel will be a pulse stream - 60 per rev in this case, and used for more accurate speed measurement. Z channel will be a single pulse every rev - ie, 1 per rev and usually required for threading so the thread starts at the same spindle angle each pass. Direction is normally calculated when there is also a B channel, which would also have 60 pulses per rev like the A channel, but is out of phase with it - ie, if A pulses come before B then its going clockwise and vice versa See this: http://quantumdevices.wordpress.com/201 ... r-encoder/As for Mach, I'm sorry I can't help with that
| Top |
CHudson
Post subject: Re: Denford Mirac Electronics Refurbishment Posted: Thu 17 Jun , 2010 20:21 pm |
Well its been a while since I updated, I managed to blow up the breakout board so I had to fit some new chips anyway...
I have made some adjustments to the program to suit the Mirac the way I have it set up. So in Mach3 when the code T0101 M6 Appears this is saying T offset, toolnumber then M6 is tool change macro
Heres the macro:
Dim Tool As Integer Dim OldTool As Integer Dim NewTool As Integer Dim MaxToolNum As Integer
MaxToolNum = 8 'Maximum positions on Automatic Tool Changer Tool = GetSelectedTool() 'Get the toolnumber from the command e.g T0101 M6 Tool number 1 OldTool = GetCurrentTool() 'Get current tool number
Call StartToolChanger
While NewTool <> Tool Call CheckPins Wend
Call StopTool
SetCurrentTool(NewTool)
'//// Subroutines /////////
Sub StartToolChanger ActivateSignal(Output3) 'Turn on output signal to turn off spindle and turn on the atc ActivateSignal(Output4) 'Turn atc forward End Sub
Sub CheckPins If IsActive(Input3) And Not IsActive(Input2) And Not IsActive(Input1) Then NewTool = 1 End If If Not IsActive(Input3) And Not IsActive(Input2) And Not IsActive(Input1) Then NewTool = 2 End If If Not IsActive(Input3) And Not IsActive(Input2) And IsActive(Input1) Then NewTool = 3 End If If IsActive(Input3) And Not IsActive(Input2) And IsActive(Input1)Then NewTool = 4 End If If IsActive(Input3) And IsActive(Input2) And IsActive(Input1) Then NewTool = 5 End If If Not IsActive(Input3) And IsActive(Input2) And IsActive(Input1)Then NewTool = 6 End If If Not IsActive(Input3) And IsActive(Input2) And Not IsActive(Input1) Then NewTool = 7 End If If IsActive(Input3) And IsActive(Input2) And Not IsActive(Input1) Then NewTool = 8 End If End Sub
Sub Stoptool DeActivateSignal(Output4) ' Stop running the ATC forward, if you don't do this the inverter will stop and the whole unit ' Will need to be turned off and on again ActivateSignal(Output5) 'Run ATC in reverse Sleep 3000 'Wait 3 seconds to allow the toolpost to lock in DeActivateSignal(Output5) 'Stop running ATC in reverse DeActivateSignal(Output3) 'Turn off output to turn spindle back on End Sub
I've yet to test it but it works fine in VBscript. Should have a chance to test it tommorow.
The outputs corrospond to the following:
Output 3 is the ATC power contactor and Spindle Power Contactor, the Spindle Power contactor is wired to the normally closed side of the relay and and ATC power contactor is wired to the normally open side of the relay
Output 4 is the ATC Forward Relay
Output 5 is the ATC Reverse Relay
| Top |
Who is online |
Users browsing this forum: No registered users and 1 guest |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot post attachments in this forum
