X HOMING PROBLEM ON VERTICAL ROUTER
Posted: Sun 07 Oct , 2018 11:44 am
I am new to this forum, and wondering if anyone can help with advise on a problem I am having on my Denford vertical router. The unit has worked fantastically for the years that I have owned it.
My issue with the unit is the x axis will no longer home. The problem started months ago, when it would require me to restart VR milling several times to get the x axis to home, the problem has got worse over time, until finally it has stopped homing completely. Before the unit stopped working, once homed it would run perfectly until switched off, problem would occur when switched on again. The system runs using a Baldor Nextmove esb2 motion controller and Baldor microflex servo control connected to baldor BSM63N-275AF Servo motor. The microflex servo control for the x axis shows a red flashing indicator when the y and z units indicators turn green. After reading the tech spec on the microflex unit, it states that 5 flashes of the indicator followed by a pause indicates a feedback error. I tried swapping the the x axis motor to the y axis connections and the problem then showed on y axis. The fact that the problem moved to the y axis lead me to think the problem was with motor unit or internal encoder.
I dismantled the end unit from the motor and found a hengstler f142500/4nf5j15 encoder inside. After finding the spec for the motor, I powered the encoder up using my bench power supply pin 1 on the plug dc+5v pin 2 ground. Using an oscilloscope I checked the outputs from the encoder, the channels pin 3 is the A channel, pin 4 is the A- channel ,pin 5 is B channel, pin 6 is B- channel, pin 7 is the Z channel and pin 8 is the Z- channel. Both A and B channels gave perfect square wave outputs, the Z channel gave a sync pulse every revolution of the encoder. On checking the U V W channels on the encoder, that I take to be feedback channels I see nothing on my scope, and am wondering if they require a load to be applied. Any advise or help would be much appreciated.
