Miro Router ignoring offsets
Posted: Sat 15 Jan , 2022 12:18 pm
Hello,
I've bought used Micro Router with VR milling V5. The router is homing properly on all axis, setting it to 0;0;0. Then, after jogging it to the material zero point I create a new offset, by activating it and hitting the XYZ button. Software is reading the new position and adjusts X Y and Z values to -xxx.xxx. After hitting the auto command every program I run starts not in the offset zero point, but in the router 0, as it was not any offset set.
I tried manually adjusting the values in AllOffest.mof file, but it did not work (the same result), same with erasing the file and letting the VR milling create a new one- the same. Router goes to right corner and starts milling in the air.
Could you please help me find a solution? I'm new to this, it is my first router and all the info I get is from your forum, youtube and manuals.
