Microrouter axes counter increments but axes do not move
- bradders
- bradders
Q.“Microrouter Axes counter increments but axes do not move”
A.Check the Axis Drive Transformer fuse (F2 6.3A) and the Axis Drive fuse (F5 6.3A)
A. Switch the Machine off for at least 2 minutes this will reset the drives if they have tripped
A. Are there any illuminated LED’s on the drive boards (May not be on all drive boards)
A. If the stepper motors “Chatter” then the wrong machine is probably selected e.g. Microrouter Pro as opposed to a Microrouter. Check the name of the machine on the Serial No plate
A.On the older DENSTEP cards there is a 6.3A fuse. Check this as not blown
- Hardware/Software: Denford Triac PNC3
FeatureCam - CADCAM
Delcam Powershape
Re: Microrouter axes counter increments but axes do not move
Hi Bradders,
I am having issues with the x axis drive on my microrouter pro, I have gone through your check list but still a problem.
The fuses are fine, switched the machine off, when ON, there are only LED's lit on the Y and Z axis, and the Y and Z axis move ok, X axis moves ok when you plug the respective cable block's into another drive.
I have checked the power supply to the board upto the block connector and this is ok, but no power to the board as the LED's arent lit.
How do the drives trip?? and is there a manual trip switch on the board?? I cant see any visible damage to the board either.
