I have successfully connected a parallel port break out board to the stepper motor driver on my ScanTek 2000 (a re-branded Denford Micromill 2000) and have the 3 axis moving under Mach3 / LinuxCNC control.
I've posted a video explaining how I did it here:
https://www.youtube.com/watch?v=oJxEdeaLSbU
My website that includes all of the pinout information and photos is here:
https://www.summet.com/blog/2016/01/16/h ... s-control/
Hopefully this documentation will assist others.
Places where I could still use some more information:
1) Which pins on the 96 way connector are for each of the limit/home switches and ESTOP / front cover open switch?
2) Which pin on the 96 way connector should I apply a PWM signal to drive the spindle driver board?
[I have the baldor-eurocard-schematic-and-pinout.pdf file, so I think I could eventually figure this out, but if somebody already has it working I'd appreciate just knowing...]
Thanks,
Jay
Update, I have gotten the home switches and estop switch working, you can see the full set of photos here:
https://www.summet.com/blog/2016/01/17/h ... es-e-stop/
Very briefly:
C26 - Home 0 (X axis). Parallel pin 10
B24 - Home 1 (Y axis). Parallel pin 11
C23 - Home 2 (Z axis). Parallel pin 12
A25 - (E-)STOP. Parallel pin 13.
If you ground C6 it enables the Spindle Go Relay (SGR), but I still don't know if there is a pin on the 96 way connector that you can PWM to control the NextMoveST SpindleOut (SOUT) 0-10 volt signal.
Very briefly:
Update 2:
I've gotten PWM spindle motor speed control using the circuitry on the NextMoveST board (via the SOUT pin that is wired to the KB spindle motor controller).
Short answer: Solder a 200-220 ohm resistor to Pin 3 of the OptoIsolator (HCNW4503) and wire that to an output. (Active when low). Also remove surface mount resistor R29, which disconnects Pin3 from the original programmable timer/counter chip that used to drive it.
Longer answer with pictures and video is located here:
https://www.summet.com/blog/2016/01/29/h ... d-control/
https://www.youtube.com/watch?v=CFH58YUjX5U
Hope this helps others,
Jay
Jay
