hi to all
I have a micromill 2000 Dec2001 Electrical Ser. No. 0C00271128 running VR2.8 with a dongle.
I keep getting an error message that states I need to connect data cable OR switch machine on, BUT the cable is connected and machine is on. at the rear of the m/c there is a circuit board top L/h side on this board is a 'number' LED this displays a 'dot' bottom L/h side and a straight line mid display. I could do with the error codes to explain what the problem is in order to get running once again.
Any help in this regard much appreciated.
regards barry
micromill 2000 error codes for led display
- usermaatresetepenre
Have a look at these:
viewtopic.php?t=544
viewtopic.php?t=653
I wouldn't read too much into the status LED - 99% of the time the problem is with the RS232 not communicating properly.
viewtopic.php?t=544
viewtopic.php?t=653
