Cyclone with 300 and 438 alarms
Posted: Tue 22 Sep , 2015 20:55 pm
by jamesgates1000
I recently bought a cyclone, it has been in storage for a while so i wasnt expecting it to start up without throwing up a few errors.
Turned it on for the first time today and it showed many errors...
401 SERVO ALARM :X AXIS VERDY OFF
438 X AXIS:INV. ABNORMAL LOAD
300 APC ALARM : X AXIS NEED ZRN
300 APC ALARM : Z AXIS NEED ZRN
300 APC ALARM : X AXIS BATTERY ZERO
300 APC ALARM : X AXIS BATTERY DOWN1
300 APC ALARM : Z AXIS BATTERY ZERO
I was unable to reset the alarms or reference the machine, so i turned it on and off again. Now there were only three alarms remaining...
Anyone have any ideas what might be causing this?
Re: Cyclone with 300 and 438 alarms
Posted: Wed 23 Sep , 2015 7:52 am
It sounds like the battery packs attached to the drives need to be replaced.
Posted: Thu 08 Oct , 2015 22:26 pm
by jamesgates1000
I have replaced the batteries, this has cleared the battery alarms but I am left with...
I guess I will need to reset the reference position to clear the two 300 alarms.
Does anyone have any idea what could be causing the 438 abnormal load alarm.
As the machine has only just been wired up, could it be that the phase rotation is out?
Posted: Fri 09 Oct , 2015 10:19 am
I can't see it being the phases but it may be worth checking the voltages.
It may also be a parameter set wrongly.
Posted: Sat 10 Oct , 2015 21:05 pm
by jamesgates1000
Someone at work suggested that it might be that the axis had seized. I took off the side panel and moved the x axis to the centre of its travel. Seemed a little stiff at first but not too bad.
Now the 401 and 438 alarms have gone, and i am getting a 441 alarm - n AXIS : ABNORMAL CURRENT OFFSET
Any idea why this might be. Also does anyone have the parameters for the fanuc beta servo drives so that i can check if mine are correct?
Posted: Sun 11 Oct , 2015 18:43 pm
I should be able to post the relevant parameters on Monday. Do you know who bought the machine from new?
Posted: Sun 11 Oct , 2015 19:31 pm
by jamesgates1000
Hi, I got the cyclone and a triac from an auctioneers, they were selling them on behalf of Gateshead college. There is Gateshead college stickers on both of them.
Posted: Thu 15 Oct , 2015 9:49 am
by jamesgates1000
Hi, did you manage to find those parameters?
Posted: Thu 15 Oct , 2015 13:03 pm
Sorry, I forgot.
N00000 P 00001010
N00001 P 00000000
N00002 P 00000000
N00012 A1 P 00000000 A2 P 00000000
N00020 P 0
N00021 P 0
N00022 P 0
N00023 P 0
N00024 P 0
N00100 P 00000000
N00101 P 00000001
N00102 P 0
N00103 P 11
N00110 P 00000000
N00111 P 10000001
N00112 P 0
N00113 P 1
N00121 P 00000001
N00122 P 0
N00123 P 0
N00131 P 00000000
N00132 P 0
N00133 P 0
N00134 P 00000000
N00135 P 00000000
N00138 P 00000000
N00140 P 00000000
N00141 P 0
N00142 P 0
N00143 P 0
N00144 P 0
N00145 P 0
N00146 P 0
N00147 P 0
N00148 P 0
N00149 P 0
N00161 P 00000000
N00162 P 00000000
N00171 P 0
N00172 P 0
N00173 P 0
N00174 P 0
N00175 P 0
N00176 P 0
N00177 P 0
N00178 P 0
N00201 P 00000000
N00203 P 0
N00204 P 0
N00206 P 0
N00231 P 00000000
N00233 P 0
N00241 P 0
N00242 P 0
N00271 P 00000000
N00272 P 0
N00273 P 0
N00281 P 00000000
N00282 P 0
N00283 P 0
N00291 P 00000000
N00292 P 0
N00293 P 0
N00300 P 00000000
N00301 P 00000000
N00801 P 00000000
N00802 P 0
N00803 P 0
N00810 P 00000000
N00811 P 0
N00812 P 0
N00813 P 0
N00814 P 0
N00815 P 0
N00820 P 0
N00821 P 0
N00822 P 0
N00823 P 0
N00824 P 0
N00825 P 0
N00826 P 0
N00827 P 0
N00828 P 0
N00850 P 00000000
N00851 P 0
N00852 P 0
N00853 P 0
N00900 P 00000000
N00901 P 00000000
N00902 P 00000000
N00903 P 00000000
N00904 P 00000000
N00905 P 00000000
N00911 P 0
N00912 P 0
N00913 P 0
N00914 P 0
N00915 P 0
N00916 P 0
N00917 P 0
N00918 P 0
N00919 P 0
N00920 P 0
N00921 P 0
N00922 P 0
N00923 P 0
N00924 P 0
N00925 P 0
N00926 P 0
N00927 P 0
N00928 P 0
N00929 P 0
N00930 P 0
N00931 P 0
N00932 P 0
N00933 P 0
N00934 P 0
N00935 P 0
N00960 P 00000000
N01001 P 00000000
N01002 P 00000000
N01003 P 00000000
N01004 P 00000000
N01005 A1 P 00000001 A2 P 00000001
N01006 A1 P 00001000 A2 P 00000000
N01007 A1 P 00000000 A2 P 00000000
N01008 A1 P 00000000 A2 P 00000000
N01010 P 2
N01015 P 00000000
N01020 A1 P 88 A2 P 90
N01022 A1 P 1 A2 P 3
N01023 A1 P 1 A2 P 2
N01031 P 0
N01201 P 00000001
N01202 P 00000000
N01220 A1 P 0 A2 P 0
N01221 A1 P 0 A2 P 0
N01222 A1 P 0 A2 P 0
N01223 A1 P 0 A2 P 0
N01224 A1 P 0 A2 P 0
N01225 A1 P 0 A2 P 0
N01226 A1 P 0 A2 P 0
N01240 A1 P 178000 A2 P 0
N01241 A1 P 0 A2 P 0
N01242 A1 P 0 A2 P 0
N01243 A1 P 0 A2 P 0
N01244 A1 P 0 A2 P 0
N01250 A1 P 178000 A2 P 0
N01251 A1 P 0 A2 P 0
N01260 A1 P 0 A2 P 0
N01290 P 0
N01300 P 10000000
N01301 P 00000000
N01310 A1 P 00000000 A2 P 00000000
N01320 A1 P 179000 A2 P 2000
N01321 A1 P-16000 A2 P-192000
N01322 A1 P 0 A2 P 0
N01323 A1 P 0 A2 P 0
N01324 A1 P 0 A2 P 0
N01325 A1 P 0 A2 P 0
N01326 A1 P 0 A2 P 0
N01327 A1 P 0 A2 P 0
N01328 A1 P 0 A2 P 0
N01329 A1 P 0 A2 P 0
N01330 P 0
N01331 P 0
N01332 P 0
N01333 P 0
N01334 P 0
N01335 P 0
N01336 P 0
N01341 P 0
N01342 P 0
N01343 P 0
N01344 P 0
N01345 P 0
N01346 P 0
N01347 P 0
N01348 P 0
N01401 P 00010000
N01402 P 00000000
N01403 P 00000000
N01404 P 00000000
N01405 P 00000000
N01406 P 00000000
N01410 P 2000
N01412 P 0
N01414 P 0
N01415 P 0
N01420 A1 P 7500 A2 P 7500
N01421 A1 P 20 A2 P 20
N01422 P 5000
N01423 A1 P 200 A2 P 200
N01424 A1 P 2000 A2 P 2000
N01425 A1 P 200 A2 P 200
N01426 P 0
N01427 A1 P 0 A2 P 0
N01430 A1 P 0 A2 P 0
N01434 A1 P 0 A2 P 0
N01435 P 0
N01440 P 0
N01441 A1 P 0 A2 P 0
N01442 A1 P 0 A2 P 0
N01443 P 0
N01444 A1 P 0 A2 P 0
N01445 A1 P 0 A2 P 0
N01601 P 00000000
N01602 P 00000000
N01603 P 00000000
N01605 P 00000000
N01610 A1 P 00000000 A2 P 00000000
N01620 A1 P 50 A2 P 50
N01621 A1 P 0 A2 P 0
N01622 A1 P 0 A2 P 0
N01623 A1 P 0 A2 P 0
N01624 A1 P 20 A2 P 20
N01625 A1 P 0 A2 P 0
N01626 A1 P 0 A2 P 0
N01627 A1 P 0 A2 P 0
N01628 P 0
N01630 P 0
N01631 P 0
N01640 A1 P 0 A2 P 0
N01641 A1 P 0 A2 P 0
N01710 P 0
N01711 P 0
N01712 P 0
N01713 P 0
N01714 P 0
N01722 A1 P 0 A2 P 0
N01723 P 0
N01724 A1 P 0 A2 P 0
N01725 A1 P 0 A2 P 0
N01730 P 0
N01731 P 0
N01732 P 0
N01740 P 0
N01741 A1 P 0 A2 P 0
N01762 A1 P 0 A2 P 0
N01763 A1 P 0 A2 P 0
N01768 P 0
N01770 P 0
N01771 P 0
N01777 P 0
N01778 P 0
N01779 P 0
N01780 P 0
N01781 A1 P 0 A2 P 0
N01782 P 0
N01783 A1 P 0 A2 P 0
N01784 P 0
N01800 P 00000010
N01801 P 00001000
N01802 P 00000000
N01803 P 00000000
N01804 P 00000000
N01805 P 00000000
N01806 P 00000000
N01815 A1 P 00110000 A2 P 00110000
N01816 A1 P 00000000 A2 P 00000000
N01817 A1 P 00000000 A2 P 00000000
N01818 A1 P 00000000 A2 P 00000000
N01819 A1 P 00000000 A2 P 00000000
N01820 A1 P 2 A2 P 2
N01821 A1 P 10000 A2 P 5000
N01825 A1 P 3000 A2 P 3000
N01826 A1 P 20 A2 P 20
N01827 A1 P 0 A2 P 0
N01828 A1 P 20000 A2 P 10000
N01829 A1 P 2000 A2 P 1000
N01830 A1 P 0 A2 P 0
N01831 A1 P 0 A2 P 0
N01832 A1 P 0 A2 P 0
N01834 A1 P 0 A2 P 0
N01836 A1 P 0 A2 P 0
N01850 A1 P 0 A2 P 0
N01851 A1 P 90 A2 P 15
N01852 A1 P 0 A2 P 0
N01853 A1 P 0 A2 P 0
N01856 P 0
N01860 A1 P 35651506 A2 P 67108745
N01861 A1 P 0 A2 P 0
N01870 A1 P 0 A2 P 0
N01871 A1 P 0 A2 P 0
N01874 A1 P 0 A2 P 0
N01875 A1 P 0 A2 P 0
N01876 A1 P 0 A2 P 0
N01877 A1 P 0 A2 P 0
N01880 P 0
N01881 A1 P 0 A2 P 0
N01882 A1 P 0 A2 P 0
N01883 A1 P 0 A2 P 0
N01884 A1 P 0 A2 P 0
N01885 A1 P 0 A2 P 0
N01886 A1 P 0 A2 P 0
N01890 P 0
N01891 P 0
N01892 P 0
N01894 A1 P 0 A2 P 0
N01901 P 00000000
N01902 P 00000010
N01904 A1 P 00000000 A2 P 00000000
N01905 A1 P 00000000 A2 P 00000001
N01910 P 0
N01911 P 1
N01912 P 40
N01913 P 40
N01914 P 40
N01915 P 40
N01916 P 40
N01917 P 40
N01918 P 40
N01919 P 40
N01920 P 1
N01921 P 2
N01922 P 0
N01923 P 0
N01924 P 0
N01925 P 0
N01926 P 0
N01927 P 0
N01928 P 0
N01929 P 0
N01931 A1 P 0 A2 P 0
N01932 A1 P 0 A2 P 0
N01933 A1 P 0 A2 P 0
N01934 A1 P 0 A2 P 0
N01936 A1 P 0 A2 P 0
N01937 A1 P 0 A2 P 0
N01941 A1 P 0 A2 P 0
N01942 A1 P 0 A2 P 0
N01943 A1 P 0 A2 P 0
N01944 A1 P 0 A2 P 0
N01945 P 0
N01955 P 0
N01956 P 0
N01957 P 0
N01958 P 0
N01959 P 00000000
N02000 A1 P 00001010 A2 P 00001010
N02001 A1 P 00000000 A2 P 00000000
N02002 A1 P 00000000 A2 P 00000000
N02003 A1 P 00001000 A2 P 00001000
N02004 A1 P 00000110 A2 P 00000110
N02005 A1 P 00000000 A2 P 00000000
N02006 A1 P 01000000 A2 P 01000000
N02007 A1 P 00000000 A2 P 00000000
N02008 A1 P 00000000 A2 P 00000000
N02009 A1 P 00000000 A2 P 00000000
N02010 A1 P 00000000 A2 P 00000000
N02011 A1 P 00100000 A2 P 00100000
N02012 A1 P 00000000 A2 P 00000000
N02013 A1 P 00000000 A2 P 00000000
N02014 A1 P 00000000 A2 P 00000000
N02015 A1 P 00000000 A2 P 00000000
N02016 A1 P 00000000 A2 P 00000000
N02017 A1 P 00000000 A2 P 00000000
N02018 A1 P 00000000 A2 P 00000000
N02019 A1 P 00000000 A2 P 00000000
N02020 A1 P 36 A2 P 36
N02021 A1 P 0 A2 P 0
N02022 A1 P-111 A2 P-111
N02023 A1 P 8192 A2 P 8192
N02024 A1 P 12500 A2 P 12500
N02025 A1 P 0 A2 P 0
N02026 A1 P 0 A2 P 0
N02027 A1 P 0 A2 P 0
N02028 A1 P 0 A2 P 0
N02029 A1 P 0 A2 P 0
N02030 A1 P 0 A2 P 0
N02031 A1 P 0 A2 P 0
N02032 A1 P 0 A2 P 0
N02033 A1 P 0 A2 P 0
N02034 A1 P 0 A2 P 0
N02035 A1 P 0 A2 P 0
N02036 A1 P 0 A2 P 0
N02037 A1 P 0 A2 P 0
N02038 A1 P 0 A2 P 0
N02039 A1 P 0 A2 P 0
N02040 A1 P 704 A2 P 704
N02041 A1 P-2401 A2 P-2401
N02042 A1 P-2596 A2 P-2596
N02043 A1 P 180 A2 P 180
N02044 A1 P-1111 A2 P-1111
N02045 A1 P 0 A2 P 0
N02046 A1 P-8235 A2 P-8235
N02047 A1 P 3415 A2 P 3415
N02048 A1 P 0 A2 P 0
N02049 A1 P 0 A2 P 0
N02050 A1 P 956 A2 P 956
N02051 A1 P 510 A2 P 510
N02052 A1 P 0 A2 P 0
N02053 A1 P 21 A2 P 21
N02054 A1 P 1894 A2 P 1894
N02055 A1 P 319 A2 P 319
N02056 A1 P 3300 A2 P 3300
N02057 A1 P-9229 A2 P-9229
N02058 A1 P-1820 A2 P-1820
N02059 A1 P 5 A2 P 5
N02060 A1 P 7282 A2 P 7282
N02061 A1 P 120 A2 P 120
N02062 A1 P 32540 A2 P 32540
N02063 A1 P 2850 A2 P 2850
N02064 A1 P 4 A2 P 4
N02065 A1 P 8474 A2 P 8474
N02066 A1 P 0 A2 P 0
N02067 A1 P 0 A2 P 0
N02068 A1 P 0 A2 P 0
N02069 A1 P 0 A2 P 0
N02070 A1 P 0 A2 P 0
N02071 A1 P 0 A2 P 0
N02072 A1 P 0 A2 P 0
N02073 A1 P 0 A2 P 0
N02074 A1 P 0 A2 P 0
N02075 A1 P 0 A2 P 0
N02076 A1 P 0 A2 P 0
N02077 A1 P 0 A2 P 0
N02078 A1 P 0 A2 P 0
N02079 A1 P 0 A2 P 0
N02080 A1 P 0 A2 P 0
N02081 A1 P 0 A2 P 0
N02082 A1 P 0 A2 P 0
N02083 A1 P 0 A2 P 0
N02084 A1 P 1 A2 P 1
N02085 A1 P 100 A2 P 200
N02086 A1 P 2142 A2 P 2142
N02087 A1 P 0 A2 P 0
N02088 A1 P 0 A2 P 0
N02089 A1 P 0 A2 P 0
N02090 A1 P 0 A2 P 0
N02091 A1 P 0 A2 P 0
N02092 A1 P 0 A2 P 0
N02093 A1 P 0 A2 P 0
N02094 A1 P 0 A2 P 0
N02095 A1 P 0 A2 P 0
N02096 A1 P 0 A2 P 0
N02097 A1 P 0 A2 P 0
N02098 A1 P-2786 A2 P-2786
N02099 A1 P 400 A2 P 400
N02100 A1 P 0 A2 P 0
N02101 A1 P 0 A2 P 0
N02102 A1 P 12000 A2 P 12000
N02103 A1 P 0 A2 P 0
N02104 A1 P 0 A2 P 0
N02105 A1 P 83 A2 P 83
N02106 A1 P 0 A2 P 0
N02107 A1 P 0 A2 P 0
N02108 A1 P 0 A2 P 0
N02109 A1 P 0 A2 P 0
N02110 A1 P 3867 A2 P 3867
N02111 A1 P 7868 A2 P 7868
N02112 A1 P 0 A2 P 0
N02113 A1 P 0 A2 P 0
N02114 A1 P 0 A2 P 0
N02115 A1 P 0 A2 P 0
N02116 A1 P 0 A2 P 0
N02117 A1 P 0 A2 P 0
N02118 A1 P 0 A2 P 0
N02119 A1 P 0 A2 P 0
N02120 A1 P 0 A2 P 0
N02121 A1 P 0 A2 P 0
N02122 A1 P 0 A2 P 0
N02123 A1 P 0 A2 P 0
N02124 A1 P 0 A2 P 0
N02125 A1 P 0 A2 P 0
N02126 A1 P 0 A2 P 0
N02127 A1 P 0 A2 P 0
N02128 A1 P 0 A2 P 0
N02129 A1 P 0 A2 P 0
N02130 A1 P 0 A2 P 0
N02131 A1 P 0 A2 P 0
N02132 A1 P 0 A2 P 0
N02133 A1 P 0 A2 P 0
N02134 A1 P 0 A2 P 0
N02135 A1 P 0 A2 P 0
N02136 A1 P 0 A2 P 0
N02137 A1 P 0 A2 P 0
N02138 A1 P 0 A2 P 0
N02139 A1 P 0 A2 P 0
N02140 A1 P 0 A2 P 0
N02141 A1 P 0 A2 P 0
N02142 A1 P 0 A2 P 0
N02143 A1 P 0 A2 P 0
N02144 A1 P 0 A2 P 0
N02145 A1 P 0 A2 P 0
N02146 A1 P 0 A2 P 0
N02147 A1 P 0 A2 P 0
N02148 A1 P 0 A2 P 0
N02149 A1 P 0 A2 P 0
N02150 A1 P 0 A2 P 0
N02151 A1 P 0 A2 P 0
N02152 A1 P 0 A2 P 0
N02153 A1 P 0 A2 P 0
N02154 A1 P 0 A2 P 0
N02155 A1 P 0 A2 P 0
N02156 A1 P 0 A2 P 0
N02157 A1 P 0 A2 P 0
N02158 A1 P 0 A2 P 0
N02159 A1 P 0 A2 P 0
N02160 A1 P 0 A2 P 0
N02161 A1 P 0 A2 P 0
N02162 A1 P 0 A2 P 0
N02163 A1 P 0 A2 P 0
N02164 A1 P 0 A2 P 0
N02165 A1 P 0 A2 P 0
N02166 A1 P 0 A2 P 0
N02167 A1 P 0 A2 P 0
N02168 A1 P 0 A2 P 0
N02169 A1 P 0 A2 P 0
N02170 A1 P 0 A2 P 0
N02171 A1 P 0 A2 P 0
N02172 A1 P 0 A2 P 0
N02173 A1 P 0 A2 P 0
N02174 A1 P 0 A2 P 0
N02175 A1 P 0 A2 P 0
N02176 A1 P 0 A2 P 0
N02177 A1 P 0 A2 P 0
N02178 A1 P 0 A2 P 0
N02179 A1 P 0 A2 P 0
N02180 A1 P 0 A2 P 0
N02181 A1 P 0 A2 P 0
N02182 A1 P 0 A2 P 0
N02183 A1 P 0 A2 P 0
N02184 A1 P 0 A2 P 0
N02185 A1 P 0 A2 P 0
N02186 A1 P 0 A2 P 0
N02187 A1 P 0 A2 P 0
N02188 A1 P 0 A2 P 0
N02189 A1 P 0 A2 P 0
N02190 A1 P 0 A2 P 0
N02191 A1 P 0 A2 P 0
N02192 A1 P 0 A2 P 0
N02193 A1 P 0 A2 P 0
N02194 A1 P 0 A2 P 0
N02195 A1 P 0 A2 P 0
N02196 A1 P 0 A2 P 0
N02197 A1 P 0 A2 P 0
N02198 A1 P 0 A2 P 0
N02199 A1 P 0 A2 P 0
N02200 A1 P 00000000 A2 P 00000000
N02201 A1 P 00000000 A2 P 00000000
N02202 A1 P 00000000 A2 P 00000000
N02203 A1 P 00000000 A2 P 00000000
N02204 A1 P 00000000 A2 P 00000000
N02205 A1 P 00000000 A2 P 00000000
N02206 A1 P 00000000 A2 P 00000000
N02207 A1 P 00000000 A2 P 00000000
N02208 A1 P 00000000 A2 P 00000000
N02209 A1 P 00000000 A2 P 00000000
N02210 A1 P 00000000 A2 P 00000000
N02211 A1 P 00000000 A2 P 00000000
N02212 A1 P 00000000 A2 P 00000000
N02213 A1 P 00000000 A2 P 00000000
N02214 A1 P 00000000 A2 P 00000000
N02215 A1 P 00000000 A2 P 00000000
N02216 A1 P 00000000 A2 P 00000000
N02217 A1 P 00000000 A2 P 00000000
N02218 A1 P 00000000 A2 P 00000000
N02219 A1 P 00000000 A2 P 00000000
N02220 A1 P 00000000 A2 P 00000000
N02221 A1 P 00000000 A2 P 00000000
N02222 A1 P 00000000 A2 P 00000000
N02223 A1 P 00000000 A2 P 00000000
N02224 A1 P 00000000 A2 P 00000000
N02225 A1 P 00000000 A2 P 00000000
N02226 A1 P 00000000 A2 P 00000000
N02227 A1 P 00000000 A2 P 00000000
N02228 A1 P 00000000 A2 P 00000000
N02229 A1 P 00000000 A2 P 00000000
N02230 A1 P 0 A2 P 0
N02231 A1 P 0 A2 P 0
N02232 A1 P 0 A2 P 0
N02233 A1 P 0 A2 P 0
N02234 A1 P 0 A2 P 0
N02235 A1 P 0 A2 P 0
N02236 A1 P 0 A2 P 0
N02237 A1 P 0 A2 P 0
N02238 A1 P 0 A2 P 0
N02239 A1 P 0 A2 P 0
N02240 A1 P 0 A2 P 0
N02241 A1 P 0 A2 P 0
N02242 A1 P 0 A2 P 0
N02243 A1 P 0 A2 P 0
N02244 A1 P 0 A2 P 0
N02245 A1 P 0 A2 P 0
N02246 A1 P 0 A2 P 0
N02247 A1 P 0 A2 P 0
N02248 A1 P 0 A2 P 0
N02249 A1 P 0 A2 P 0
N02250 A1 P 0 A2 P 0
N02251 A1 P 0 A2 P 0
N02252 A1 P 0 A2 P 0
N02253 A1 P 0 A2 P 0
N02254 A1 P 0 A2 P 0
N02255 A1 P 0 A2 P 0
N02256 A1 P 0 A2 P 0
N02257 A1 P 0 A2 P 0
N02258 A1 P 0 A2 P 0
N02259 A1 P 0 A2 P 0
N02260 A1 P 0 A2 P 0
N02261 A1 P 0 A2 P 0
N02262 A1 P 0 A2 P 0
N02263 A1 P 0 A2 P 0
N02264 A1 P 0 A2 P 0
N02265 A1 P 0 A2 P 0
N02266 A1 P 0 A2 P 0
N02267 A1 P 0 A2 P 0
N02268 A1 P 0 A2 P 0
N02269 A1 P 0 A2 P 0
N03001 P 00000000
N03002 P 00000000
N03003 P 00000100
N03004 P 00100000
N03006 P 00000000
N03007 P 00000000
N03010 P 0
N03011 P 0
N03016 P 0
N03017 P 0
N03018 P 0
N03030 P 0
N03031 P 0
N03032 P 0
N03033 P 0
N03100 P 00000000
N03101 P 00000000
N03102 P 00000000
N03103 P 00000000
N03104 P 00000000
N03105 P 00000101
N03106 P 00010010
N03107 P 00010001
N03108 P 10000000
N03109 P 00000000
N03110 P 00000000
N03111 P 01100001
N03112 P 00001100
N03113 P 10000000
N03114 P 00000000
N03115 A1 P 00000000 A2 P 00000000
N03116 P 00000000
N03117 P 00000000
N03118 P 00000000
N03119 P 00000000
N03120 P 0
N03121 P 0
N03122 P 10
N03123 P 0
N03124 P 00000000
N03125 P 00000000
N03126 P 00000000
N03127 P 00000000
N03128 P 0
N03130 A1 P 0 A2 P 0
N03131 A1 P 0 A2 P 0
N03132 A1 P 0 A2 P 0
N03133 A1 P 0 A2 P 0
N03134 A1 P 0 A2 P 0
N03140 P 0
N03141 P 0
N03142 P 0
N03143 P 0
N03144 P 0
N03145 P 0
N03146 P 0
N03147 P 0
N03151 P 0
N03152 P 0
N03153 P 0
N03154 P 0
N03155 P 0
N03156 P 0
N03157 P 0
N03158 P 0
N03161 P 0
N03162 P 0
N03163 P 0
N03165 P 0
N03170 P 0
N03190 P 00000000
N03191 P 00000000
N03192 P 00000000
N03198 P 0
N03199 P 0
N03201 P 11100000
N03202 P 00000000
N03203 P 00000000
N03204 P 00000100
N03205 P 00000000
N03206 P 00000000
N03207 P 00000000
N03208 P 00000000
N03209 P 00000000
N03212 P 0
N03213 P 0
N03215 P 0
N03216 P 10
N03218 P 0
N03219 P 0
N03260 P 00000000
N03270 P 0
N03271 P 0
N03290 P 10000000
N03291 P 00000000
N03292 P 00000000
N03294 P 0
N03295 P 0
N03301 P 00000000
N03310 P 0
N03311 P 0
N03401 P 00000001
N03402 P 00000000
N03403 P 00000000
N03404 P 00000000
N03405 P 00000000
N03406 P 00000000
N03407 P 00000000
N03408 P 00000000
N03409 P 00000000
N03410 P 0
N03411 P 15
N03412 P 0
N03413 P 0
N03414 P 0
N03415 P 0
N03416 P 0
N03417 P 0
N03418 P 0
N03419 P 0
N03420 P 0
N03421 P 0
N03422 P 0
N03423 P 0
N03424 P 0
N03425 P 0
N03426 P 0
N03427 P 0
N03428 P 0
N03429 P 0
N03430 P 0
N03431 P 0
N03432 P 0
N03450 P 00000000
N03451 P 00000000
N03453 P 00000000
N03601 P 00000000
N03620 A1 P 0 A2 P 0
N03621 A1 P 0 A2 P 0
N03622 A1 P 0 A2 P 0
N03623 A1 P 0 A2 P 0
N03624 A1 P 0 A2 P 0
N03625 A1 P 0 A2 P 0
N03700 P 00000000
N03701 P 00000000
N03702 P 00000000
N03703 P 00000000
N03704 P 00000000
N03705 P 00000000
N03706 P 00000000
N03707 P 00000000
N03708 P 00000000
N03709 P 00000000
N03710 P 00000000
N03715 A1 P 00000000 A2 P 00000000
N03721 P 0
N03722 P 0
N03723 P 0
N03724 P 0
N03725 P 0
N03726 P 0
N03727 P 0
N03728 P 0
N03730 P 1000
N03731 P 0
N03732 P 0
N03740 P 0
N03741 P 5000
N03742 P 5000
N03743 P 5000
N03744 P 5000
N03770 P 0
N03771 P 0
N03772 P 5000
N03800 P 0
N03801 P 0
N03802 P 0
N03811 P 0
N03812 P 0
N03820 P 0
N03821 P 0
N03822 P 0
N03831 P 0
N03832 P 0
N03841 P 0
N03842 P 0
N03843 P 0
N03850 P 0
N03851 P 0
N03852 P 0
N03900 P 0
N03901 P 0
N03902 P 0
N03903 P 0
N03904 P 0
N03910 P 0
N03911 P 0
N03912 P 0
N03913 P 0
N03914 P 0
N03920 P 0
N03921 P 0
N03922 P 0
N03923 P 0
N03924 P 0
N03930 P 0
N03931 P 0
N03932 P 0
N03933 P 0
N03934 P 0
N04000 A1 P 00000000
N04001 A1 P 00000000
N04002 A1 P 00000000
N04003 A1 P 00000000
N04004 A1 P 00000000
N04005 A1 P 00000000
N04006 A1 P 00000000
N04007 A1 P 00000000
N04008 A1 P 00000000
N04009 A1 P 00000000
N04010 A1 P 00000000
N04011 A1 P 00000000
N04012 A1 P 00000000
N04013 A1 P 00000000
N04014 A1 P 00000000
N04015 A1 P 00000000
N04016 A1 P 00000000
N04017 A1 P 00000000
N04018 A1 P 00000000
N04019 A1 P 00000000
N04020 A1 P 0
N04021 A1 P 0
N04022 A1 P 0
N04023 A1 P 0
N04024 A1 P 0
N04025 A1 P 0
N04026 A1 P 0
N04027 A1 P 0
N04028 A1 P 0
N04029 A1 P 0
N04030 A1 P 0
N04031 A1 P 0
N04032 A1 P 0
N04033 A1 P 0
N04034 A1 P 0
N04035 A1 P 0
N04036 A1 P 0
N04037 A1 P 0
N04038 A1 P 0
N04039 A1 P 0
N04040 A1 P 0
N04041 A1 P 0
N04042 A1 P 0
N04043 A1 P 0
N04044 A1 P 0
N04045 A1 P 0
N04046 A1 P 0
N04047 A1 P 0
N04048 A1 P 0
N04049 A1 P 0
N04050 A1 P 0
N04051 A1 P 0
N04052 A1 P 0
N04053 A1 P 0
N04054 A1 P 0
N04055 A1 P 0
N04056 A1 P 0
N04057 A1 P 0
N04058 A1 P 0
N04059 A1 P 0
N04060 A1 P 0
N04061 A1 P 0
N04062 A1 P 0
N04063 A1 P 0
N04064 A1 P 0
N04065 A1 P 0
N04066 A1 P 0
N04067 A1 P 0
N04068 A1 P 0
N04069 A1 P 0
N04070 A1 P 0
N04071 A1 P 0
N04072 A1 P 0
N04073 A1 P 0
N04074 A1 P 0
N04075 A1 P 0
N04076 A1 P 0
N04077 A1 P 0
N04078 A1 P 0
N04079 A1 P 0
N04080 A1 P 0
N04081 A1 P 0
N04082 A1 P 0
N04083 A1 P 0
N04084 A1 P 0
N04085 A1 P 0
N04086 A1 P 0
N04087 A1 P 0
N04088 A1 P 0
N04089 A1 P 0
N04090 A1 P 0
N04091 A1 P 0
N04092 A1 P 0
N04093 A1 P 4532
N04094 A1 P 0
N04095 A1 P 0
N04096 A1 P 0
N04097 A1 P 0
N04098 A1 P 0
N04099 A1 P 0
N04100 A1 P 0
N04101 A1 P 0
N04102 A1 P 0
N04103 A1 P 0
N04104 A1 P 0
N04105 A1 P 0
N04106 A1 P 0
N04107 A1 P 0
N04108 A1 P 0
N04109 A1 P 0
N04110 A1 P 0
N04111 A1 P 0
N04112 A1 P 0
N04113 A1 P 0
N04114 A1 P 0
N04115 A1 P 0
N04116 A1 P 0
N04117 A1 P 0
N04118 A1 P 0
N04119 A1 P 0
N04120 A1 P 0
N04121 A1 P 0
N04122 A1 P 0
N04123 A1 P 0
N04124 A1 P 0
N04125 A1 P 0
N04126 A1 P 0
N04127 A1 P 0
N04128 A1 P 0
N04129 A1 P 0
N04130 A1 P 0
N04131 A1 P 0
N04132 A1 P 0
N04133 A1 P 0
N04134 A1 P 0
N04135 A1 P 0
N04136 A1 P 0
N04137 A1 P 0
N04138 A1 P 0
N04139 A1 P 0
N04140 A1 P 0
N04141 A1 P 0
N04142 A1 P 0
N04143 A1 P 0
N04144 A1 P 0
N04145 A1 P 0
N04146 A1 P 0
N04147 A1 P 0
N04148 A1 P 0
N04149 A1 P 0
N04150 A1 P 0
N04151 A1 P 0
N04152 A1 P 0
N04153 A1 P 0
N04154 A1 P 0
N04155 A1 P 0
N04156 A1 P 0
N04157 A1 P 0
N04158 A1 P 0
N04159 A1 P 0
N04160 A1 P 0
N04161 A1 P 0
N04162 A1 P 0
N04163 A1 P 0
N04164 A1 P 0
N04165 A1 P 0
N04166 A1 P 0
N04167 A1 P 0
N04168 A1 P 0
N04169 A1 P 0
N04170 A1 P 0
N04171 A1 P 0
N04172 A1 P 0
N04173 A1 P 0
N04174 A1 P 0
N04175 A1 P 0
N04176 A1 P 00000000
N04177 A1 P 00000000
N04178 A1 P 00000000
N04179 A1 P 00000000
N04180 A1 P 00000000
N04181 A1 P 00000000
N04182 A1 P 00000000
N04183 A1 P 00000000
N04184 A1 P 00000000
N04185 A1 P 00000000
N04186 A1 P 00000000
N04187 A1 P 00000000
N04188 A1 P 00000000
N04189 A1 P 00000000
N04190 A1 P 00000000
N04191 A1 P 00000000
N04192 A1 P 00000000
N04193 A1 P 00000000
N04194 A1 P 00000000
N04195 A1 P 00000000
N04196 A1 P 0
N04197 A1 P 0
N04198 A1 P 0
N04199 A1 P 0
N04200 A1 P 0
N04201 A1 P 0
N04202 A1 P 0
N04203 A1 P 0
N04204 A1 P 0
N04205 A1 P 0
N04206 A1 P 0
N04207 A1 P 0
N04208 A1 P 0
N04209 A1 P 0
N04210 A1 P 0
N04211 A1 P 0
N04212 A1 P 0
N04213 A1 P 0
N04214 A1 P 0
N04215 A1 P 0
N04216 A1 P 0
N04217 A1 P 0
N04218 A1 P 0
N04219 A1 P 0
N04220 A1 P 0
N04221 A1 P 0
N04222 A1 P 0
N04223 A1 P 0
N04224 A1 P 0
N04225 A1 P 0
N04226 A1 P 0
N04227 A1 P 0
N04228 A1 P 0
N04229 A1 P 0
N04230 A1 P 0
N04231 A1 P 0
N04232 A1 P 0
N04233 A1 P 0
N04234 A1 P 0
N04235 A1 P 0
N04236 A1 P 0
N04237 A1 P 0
N04238 A1 P 0
N04239 A1 P 0
N04240 A1 P 0
N04241 A1 P 0
N04242 A1 P 0
N04243 A1 P 0
N04244 A1 P 0
N04245 A1 P 0
N04246 A1 P 0
N04247 A1 P 0
N04248 A1 P 0
N04249 A1 P 0
N04250 A1 P 0
N04251 A1 P 0
N04252 A1 P 0
N04253 A1 P 0
N04254 A1 P 0
N04255 A1 P 0
N04256 A1 P 0
N04257 A1 P 0
N04258 A1 P 0
N04259 A1 P 0
N04260 A1 P 0
N04261 A1 P 0
N04262 A1 P 0
N04263 A1 P 0
N04264 A1 P 0
N04265 A1 P 0
N04266 A1 P 0
N04267 A1 P 0
N04268 A1 P 0
N04269 A1 P 0
N04270 A1 P 0
N04271 A1 P 0
N04272 A1 P 0
N04273 A1 P 0
N04274 A1 P 0
N04275 A1 P 0
N04276 A1 P 0
N04277 A1 P 0
N04278 A1 P 0
N04279 A1 P 32
N04280 A1 P 0
N04281 A1 P 0
N04282 A1 P 0
N04283 A1 P 0
N04284 A1 P 0
N04285 A1 P 0
N04286 A1 P 0
N04287 A1 P 0
N04288 A1 P 0
N04289 A1 P 0
N04290 A1 P 0
N04291 A1 P 0
N04292 A1 P 0
N04293 A1 P 0
N04294 A1 P 0
N04295 A1 P 0
N04296 A1 P 0
N04297 A1 P 0
N04298 A1 P 0
N04299 A1 P 0
N04300 A1 P 0
N04301 A1 P 0
N04302 A1 P 0
N04303 A1 P 0
N04304 A1 P 0
N04305 A1 P 0
N04306 A1 P 0
N04307 A1 P 0
N04308 A1 P 0
N04309 A1 P 0
N04310 A1 P 0
N04311 A1 P 0
N04312 A1 P 0
N04313 A1 P 0
N04314 A1 P 0
N04315 A1 P 0
N04316 A1 P 0
N04317 A1 P 0
N04318 A1 P 0
N04319 A1 P 0
N04320 A1 P 0
N04321 A1 P 0
N04322 A1 P 0
N04323 A1 P 0
N04324 A1 P 0
N04325 A1 P 0
N04326 A1 P 0
N04327 A1 P 0
N04328 A1 P 0
N04329 A1 P 0
N04330 A1 P 0
N04331 A1 P 0
N04332 A1 P 0
N04333 A1 P 0
N04334 A1 P 0
N04335 A1 P 0
N04336 A1 P 0
N04337 A1 P 0
N04338 A1 P 0
N04339 A1 P 0
N04340 A1 P 0
N04341 A1 P 0
N04342 A1 P 0
N04343 A1 P 0
N04344 A1 P 0
N04345 A1 P 0
N04346 A1 P 0
N04347 A1 P 0
N04348 A1 P 0
N04349 A1 P 0
N04350 A1 P 0
N04351 A1 P 0
N04352 A1 P 00000000
N04353 A1 P 00000000
N04354 A1 P 0
N04355 A1 P 0
N04356 A1 P 0
N04357 A1 P 0
N04358 A1 P 0
N04359 A1 P 0
N04360 A1 P 0
N04361 A1 P 0
N04362 A1 P 0
N04363 A1 P 0
N04364 A1 P 0
N04365 A1 P 0
N04366 A1 P 0
N04367 A1 P 0
N04368 A1 P 0
N04369 A1 P 0
N04370 A1 P 0
N04371 A1 P 0
N04372 A1 P 0
N04373 A1 P 00000000
N04374 A1 P 00000000
N04375 A1 P 0
N04376 A1 P 0
N04377 A1 P 0
N04378 A1 P 0
N04379 A1 P 0
N04380 A1 P 0
N04381 A1 P 0
N04382 A1 P 0
N04383 A1 P 0
N04384 A1 P 0
N04385 A1 P 0
N04386 A1 P 0
N04387 A1 P 0
N04388 A1 P 0
N04389 A1 P 0
N04390 A1 P 0
N04391 A1 P 0
N04392 A1 P 0
N04393 A1 P 0
N04800 P 00000000
N04810 P 0
N04811 P 0
N04815 P 0
N04817 P 0
N04821 P 0
N04822 P 0
N04823 P 0
N04824 P 0
N04826 P 0
N04827 P 0
N04828 P 0
N04829 P 0
N04831 P 0
N04832 P 0
N04833 P 0
N04834 P 0
N04900 P 00000000
N04911 P 0
N04912 P 0
N04913 P 0
N04914 P 0
N04950 P 00000000
N04960 P 0
N04961 P 0
N04962 P 0
N04963 P 0
N04964 P 0
N04970 P 0
N04971 P 0
N04972 P 0
N04973 P 0
N04974 P 0
N04981 P 0
N04982 P 0
N05001 P 00000000
N05002 P 00000100
N05003 P 00000000
N05004 P 00000000
N05005 P 00000000
N05006 P 00000000
N05007 P 00000000
N05008 P 00000000
N05009 P 00000000
N05010 P 0
N05013 P 0
N05014 P 0
N05015 P 0
N05016 P 0
N05017 P 0
N05018 P 0
N05020 P 0
N05021 P 0
N05101 P 00000000
N05102 P 00000000
N05103 P 00000000
N05110 P 0
N05111 P 0
N05112 P 0
N05113 P 0
N05114 P 0
N05130 P 15
N05132 P 500
N05133 P 500
N05134 P 0
N05135 P 0
N05136 P 0
N05137 P 0
N05139 P 0
N05140 P 150
N05141 P 150
N05142 P 3
N05143 P 60
N05200 P 00000000
N05201 P 00000000
N05203 P 00000000
N05204 P 00000000
N05205 P 00000000
N05210 P 0
N05211 P 0
N05212 P 0
N05213 P 0
N05214 P 0
N05215 P 0
N05216 P 0
N05217 P 0
N05221 P 0
N05222 P 0
N05223 P 0
N05224 P 0
N05225 P 0
N05226 P 0
N05227 P 0
N05228 P 0
N05229 P 0
N05230 P 0
N05231 P 0
N05232 P 0
N05233 P 0
N05234 P 0
N05235 P 0
N05236 P 0
N05237 P 0
N05238 P 0
N05239 P 0
N05240 P 0
N05241 P 0
N05242 P 0
N05243 P 0
N05244 P 0
N05245 P 0
N05246 P 0
N05247 P 0
N05248 P 0
N05249 P 0
N05250 P 0
N05261 P 0
N05262 P 0
N05263 P 0
N05264 P 0
N05265 P 0
N05266 P 0
N05267 P 0
N05268 P 0
N05269 P 0
N05270 P 0
N05271 P 0
N05272 P 0
N05273 P 0
N05274 P 0
N05280 P 0
N05281 P 0
N05282 P 0
N05283 P 0
N05284 P 0
N05291 P 0
N05292 P 0
N05293 P 0
N05294 P 0
N05300 P 0
N05301 P 0
N05302 P 0
N05303 P 0
N05304 P 0
N05305 P 0
N05306 P 0
N05307 P 0
N05308 P 0
N05310 P 0
N05311 P 0
N05312 P 0
N05313 P 0
N05314 P 0
N05321 P 0
N05322 P 0
N05323 P 0
N05324 P 0
N05325 P 0
N05326 P 0
N05327 P 0
N05328 P 0
N05329 P 0
N05330 P 0
N05335 P 0
N05336 P 0
N05337 P 0
N05338 P 0
N05339 P 0
N05340 P 0
N05341 P 0
N05342 P 0
N05343 P 0
N05344 P 0
N05345 P 0
N05346 P 0
N05347 P 0
N05348 P 0
N05349 P 0
N05350 P 0
N05351 P 0
N05352 P 0
N05353 P 0
N05354 P 0
N05355 P 0
N05356 P 0
N05357 P 0
N05358 P 0
N05359 P 0
N05360 P 0
N05361 P 0
N05390 P 0
N05391 P 0
N05392 P 0
N05393 P 0
N05394 P 0
N05450 P 00000000
N05460 P 0
N05461 P 0
N05462 P 0
N05463 P 0
N05660 P 0
N05661 P 0
N05662 P 0
N05663 P 0
N05664 P 0
N05665 P 0
N05666 P 0
N05667 P 0
N05670 P 0
N05671 P 0
N05672 P 0
N05673 P 0
N05674 P 0
N05675 P 0
N05676 P 0
N05677 P 0
N05680 P 0
N05681 P 0
N05682 P 0
N05683 P 0
N05684 P 0
N05685 P 0
N05686 P 0
N05687 P 0
N05690 P 0
N05691 P 0
N05692 P 0
N05693 P 0
N06000 P 00000000
N06001 P 00000000
N06003 P 00000000
N06004 P 00000000
N06005 P 00000000
N06010 P 00000000
N06011 P 00000000
N06012 P 00000000
N06013 P 00000000
N06014 P 00000000
N06030 P 0
N06033 P 0
N06034 P 0
N06036 P 0
N06037 P 0
N06050 P 0
N06051 P 0
N06052 P 0
N06053 P 0
N06054 P 0
N06055 P 0
N06056 P 0
N06057 P 0
N06058 P 0
N06059 P 0
N06071 P 0
N06072 P 0
N06073 P 0
N06074 P 0
N06075 P 0
N06076 P 0
N06077 P 0
N06078 P 0
N06079 P 0
N06080 P 0
N06081 P 0
N06082 P 0
N06083 P 0
N06084 P 0
N06085 P 0
N06086 P 0
N06087 P 0
N06088 P 0
N06089 P 0
N06090 P 0
N06091 P 0
N06092 P 0
N06101 P 0
N06102 P 0
N06103 P 0
N06104 P 0
N06105 P 0
N06106 P 0
N06107 P 0
N06108 P 0
N06109 P 0
N06110 P 0
N06200 P 00000000
N06201 P 00000000
N06202 P 00000000
N06203 P 00000000
N06204 P 00000000
N06205 P 00000000
N06206 P 00000000
N06207 P 00000000
N06215 A1 P 00000000 A2 P 00000000
N06240 P 00000000
N06241 P 0
N06251 P 0
N06252 P 0
N06254 P 0
N06255 P 0
N06300 P 00000000
N06350 P 00000000
N06360 P 0
N06361 P 0
N06362 P 0
N06363 P 0
N06381 A1 P 00000000 A2 P 00000000
N06390 A1 P 0 A2 P 0
N06391 A1 P 0 A2 P 0
N06392 A1 P 0 A2 P 0
N06393 A1 P 0 A2 P 0
N06394 A1 P 0 A2 P 0
N06395 A1 P 0 A2 P 0
N06400 P 00000000
N06410 P 0
N06411 P 0
N06412 P 0
N06413 P 0
N06414 P 0
N06415 P 0
N06416 P 0
N06417 P 0
N06418 P 0
N06419 P 0
N06420 P 0
N06421 P 0
N06422 P 0
N06423 P 0
N06424 P 0
N06425 P 0
N06426 P 0
N06427 P 0
N06428 P 0
N06429 P 0
N06430 P 0
N06431 P 0
N06432 P 0
N06433 P 0
N06434 P 0
N06435 P 0
N06436 P 0
N06437 P 0
N06438 P 0
N06439 P 0
N06440 P 0
N06441 P 0
N06442 P 0
N06443 P 0
N06444 P 0
N06445 P 0
N06446 P 0
N06447 P 0
N06448 P 0
N06449 P 0
N06450 P 0
N06451 P 0
N06452 P 0
N06453 P 0
N06454 P 0
N06455 P 0
N06456 P 0
N06457 P 0
N06458 P 0
N06459 P 0
N06460 P 0
N06461 P 0
N06462 P 0
N06463 P 0
N06464 P 0
N06465 P 0
N06466 P 0
N06467 P 0
N06468 P 0
N06469 P 0
N06470 P 0
N06471 P 0
N06472 P 0
N06473 P 0
N06474 P 0
N06475 P 0
N06476 P 0
N06477 P 0
N06478 P 0
N06479 P 0
N06480 P 0
N06481 P 0
N06482 P 0
N06483 P 0
N06484 P 0
N06485 P 0
N06486 P 0
N06487 P 0
N06488 P 0
N06489 P 0
N06490 P 0
N06500 P 00000000
N06501 P 00000000
N06502 P 00000000
N06503 P 00000000
N06509 P 0
N06510 P 0
N06520 P 0
N06530 P 0
N06531 P 0
N06532 P 0
N06533 P 0
N06561 P 0
N06562 P 0
N06563 P 0
N06564 P 0
N06565 P 0
N06566 P 0
N06567 P 0
N06568 P 0
N06569 P 0
N06570 P 0
N06571 P 0
N06572 P 0
N06573 P 0
N06574 P 0
N06575 P 0
N06581 P 0
N06582 P 0
N06583 P 0
N06584 P 0
N06585 P 0
N06586 P 0
N06587 P 0
N06588 P 0
N06589 P 0
N06590 P 0
N06591 P 0
N06592 P 0
N06593 P 0
N06594 P 0
N06595 P 0
N06700 P 00000000
N06710 P 31
N06711 P 54
N06712 P 60
N06713 P 0
N06750 P 5626
N06751 P 18624
N06752 P 199
N06753 P 28136
N06754 P 152
N06755 P 0
N06756 P 0
N06757 P 0
N06758 P 0
N06800 P 00000000
N06801 P 00000000
N06802 P 00000000
N06803 P 00000000
N06804 P 00000000
N06810 P 0
N06811 P 0
N06840 P 0
N06841 P 0
N06842 P 0
N06843 P 0
N06901 P 00000000
N06910 P 0
N06911 P 0
N06912 P 0
N06913 P 0
N06914 P 0
N06915 P 0
N06916 P 0
N06917 P 0
N06918 P 0
N06919 P 0
N06920 P 0
N06921 P 0
N06922 P 0
N06923 P 0
N06924 P 0
N06925 P 0
N06930 P 0
N06931 P 0
N06932 P 0
N06933 P 0
N06934 P 0
N06935 P 0
N06936 P 0
N06937 P 0
N06938 P 0
N06939 P 0
N06940 P 0
N06941 P 0
N06942 P 0
N06943 P 0
N06944 P 0
N06945 P 0
N06950 P 0
N06951 P 0
N06952 P 0
N06953 P 0
N06954 P 0
N06955 P 0
N06956 P 0
N06957 P 0
N06958 P 0
N06959 P 0
N06960 P 0
N06961 P 0
N06962 P 0
N06963 P 0
N06964 P 0
N06965 P 0
N06990 P 0
N06991 P 0
N06992 P 0
N06993 P 0
N07001 P 00000000
N07002 P 00000000
N07010 A1 P 00000000 A2 P 00000000
N07015 P 0
N07050 P 00000000
N07051 P 00000000
N07100 P 00000001
N07101 P 00000000
N07102 A1 P 00000000 A2 P 00000000
N07103 P 00000000
N07104 P 00000000
N07105 P 00000000
N07110 P 1
N07113 P 100
N07114 P 0
N07115 P 0
N07116 P 0
N07117 P 100
N07120 P 0
N07121 P 0
N07124 A1 P 0 A2 P 0
N07131 P 0
N07132 P 0
N07133 P 0
N07134 P 0
N07135 P 0
N07136 P 0
N07160 P 0
N07161 P 0
N07181 A1 P 0 A2 P 0
N07182 A1 P 0 A2 P 0
N07183 A1 P 0 A2 P 0
N07184 A1 P 0 A2 P 0
N07185 A1 P 0 A2 P 0
N07186 A1 P 0 A2 P 0
N07200 P 00000000
N07201 P 00000000
N07210 P 0
N07211 P 0
N07212 P 0
N07213 P 0
N07214 P 0
N07215 P 0
N07220 P 0
N07221 P 0
N07222 P 0
N07223 P 0
N07224 P 0
N07225 P 0
N07226 P 0
N07227 P 0
N07228 P 0
N07229 P 0
N07230 P 0
N07231 P 0
N07232 P 0
N07233 P 0
N07234 P 0
N07235 P 0
N07236 P 0
N07237 P 0
N07238 P 0
N07239 P 0
N07240 P 0
N07241 P 0
N07242 P 0
N07243 P 0
N07244 P 0
N07245 P 0
N07246 P 0
N07247 P 0
N07248 P 0
N07249 P 0
N07250 P 0
N07251 P 0
N07252 P 0
N07253 P 0
N07254 P 0
N07255 P 0
N07256 P 0
N07257 P 0
N07258 P 0
N07259 P 0
N07260 P 0
N07261 P 0
N07262 P 0
N07263 P 0
N07264 P 0
N07265 P 0
N07266 P 0
N07267 P 0
N07268 P 0
N07269 P 0
N07270 P 0
N07271 P 0
N07272 P 0
N07273 P 0
N07274 P 0
N07275 P 0
N07276 P 0
N07277 P 0
N07278 P 0
N07279 P 0
N07280 P 0
N07281 P 0
N07282 P 0
N07283 P 0
N07284 P 0
N07285 P 0
N07286 P 0
N07287 P 0
N07288 P 0
N07289 P 0
N07290 P 0
N07291 P 0
N07292 P 0
N07293 P 0
N07294 P 0
N07295 P 0
N07296 P 0
N07297 P 0
N07298 P 0
N07299 P 0
N07300 P 00000000
N07310 A1 P 0 A2 P 0
N07352 P 0
N07353 P 0
N07354 P 0
N07355 P 0
N07356 P 0
N07357 P 0
N07358 P 0
N07359 P 0
N07360 P 0
N07361 P 0
N07362 P 0
N07363 P 0
N07364 P 0
N07365 P 0
N07366 P 0
N07367 P 0
N07368 P 0
N07369 P 0
N07370 P 0
N07371 P 0
N07372 P 0
N07373 P 0
N07374 P 0
N07375 P 0
N07376 P 0
N07377 P 0
N07378 P 0
N07379 P 0
N07380 P 0
N07381 P 0
N07382 P 0
N07383 P 0
N07384 P 0
N07385 P 0
N07386 P 0
N07387 P 0
N07388 P 0
N07389 P 0
N07390 P 0
N07391 P 0
N07392 P 0
N07393 P 0
N07394 P 0
N07395 P 0
N07396 P 0
N07397 P 0
N07398 P 0
N07399 P 0
N07501 P 00000000
N07502 P 00000000
N07503 P 00000000
N07505 A1 P 00000000 A2 P 00000000
N07510 P 0
N07511 P 0
N07512 P 0
N07514 A1 P 0 A2 P 0
N07515 P 0
N07520 P 0
N07561 P 00000000
N07600 P 00000000
N07602 P 00000000
N07603 P 00000000
N07610 P 0
N07620 P 0
N07621 P 0
N07625 P 0
N07631 P 0
N07632 P 0
N07635 P 0
N07636 P 0
N07640 P 0
N07641 P 0
N07730 A1 P 00000000 A2 P 00000000
N07740 A1 P 0 A2 P 0
N07741 A1 P 0 A2 P 0
N07901 P 00000000
N07902 P 00000000
N07911 P 0
N07912 P 0
N07913 P 0
N07914 P 0
N07915 P 0
N07916 P 0
N08001 P 00000000
N08002 P 00000000
N08003 P 00000000
N08004 P 00000000
N08005 P 00000000
N08008 A1 P 00000000 A2 P 00000000
N08010 A1 P 0 A2 P 0
N08020 A1 P 0 A2 P 0
N08021 A1 P 0 A2 P 0
N08022 A1 P 0 A2 P 0
N08028 A1 P 0 A2 P 0
N08030 A1 P 0 A2 P 0
N08031 A1 P 0 A2 P 0
N08040 A1 P 0 A2 P 0
N08100 P 00000000
N08101 P 00000000
N08110 P 0
N08111 P 0
N08113 P 0
N08200 P 00000000
N08210 P 0
N08211 P 0
N08212 P 0
N08240 P 00000000
N08241 P 00000000
N08242 P 00000000
N08250 P 0
N08251 P 0
N08252 P 0
N08253 P 0
N08257 P 0
N08258 P 0
N08311 A1 P 0 A2 P 0
N08312 A1 P 0 A2 P 0
N08341 P 0
N08342 P 0
N08343 P 0
N08500 P 00000000
N08501 P 00000000
N08504 P 00000000
N08505 P 00000000
N08508 P 00000000
N08509 P 00000000
N08512 P 00000000
N08513 P 00000000
N08516 P 00000000
N08517 P 00000000
N08565 P 0
N08570 P 0
N08571 P 0
N08572 P 0
N08573 P 0
N08574 P 0
N08575 P 0
N08576 P 0
N08577 P 0
N08578 P 0
N08579 P 0
N08580 P 0
N08581 P 0
N08582 P 0
N08583 P 0
N08584 P 0
N08585 P 0
N08586 P 0
N08587 P 0
N08588 P 0
N08589 P 0
N08590 P 0
N08591 P 0
N08592 P 0
N08593 P 0
N08594 P 0
N08595 P 0
N08596 P 0
N08597 P 0
N08598 P 0
N08599 P 0
N08650 P 00000000
N08651 P 00000000
N08652 P 00000000
N08661 P 0
N08662 P 0
N08663 P 0
N08700 P 00000000
N08701 P 00000000
N08702 P 00000000
N08703 P 00000000
N08706 P 00000000
N08707 P 00000000
N08710 P 0
N08751 P 0
N08760 P 0
N08781 P 0
N08790 P 0
N08801 P 00000000
N08802 P 00000000
N08811 P 0
N08812 P 0
N08813 P 0
N08900 P 00000001
N08901 P 00000000
N08902 P 00000000
N08903 P 00000000
N08904 P 00000000
N08910 P 0
N08911 P 0
N08920 P 0
N08921 P 0
N08922 P 0
N08940 P 0
N08941 P 0
N08942 P 0
N08943 P 0
N08944 P 0
N08945 P 0
N08946 P 0
N08947 P 0
N08948 P 0
N08949 P 0
N08950 P 00000000
N08960 P 0
N08961 P 0
N08962 P 0
N08970 P 0
N08971 P 0
N08972 P 0
N08973 P 0
N08980 P 00000000
N08981 P 0
N08982 P 0
N08983 P 0
N08984 P 0
N09900 P 2
N09901 P 0
N09902 P 0
N09920 P 00011000
N09921 P 11000000
N09922 P 00000100
N09923 P 00000000
N09924 P 00000000
N09925 P 00000000
N09926 P 00100000
N09927 P 01010000
N09928 P 00000000
N09929 P 01000000
N09930 P 00000000
N09931 P 00000000
N09932 P 00000000
N09933 P 00000000
N09934 P 00000000
N09935 P 00000000
N09936 P 00000000
N09937 P 00000000
N09938 P 00000000
N09939 P 00000000
N09940 P 00000000
N09941 P 00000000
N09942 P 00000000
N09943 P 00000000
N09944 P 00000000
N09945 P 00000000
N09946 P 00010000
N09947 P 00000000
N09948 P 00000000
N09949 P 00000000
N09950 P 00000000
N09951 P 00000000
N09952 P 00000000
N09953 P 00000000
N09954 P 00000000
N09955 P 00000000
N09956 P 00000000
N09957 P 00000000
N09958 P 00000000
N09959 P 00000000
N09960 P 00000000
N09961 P 00000000
N09962 P 00000000
N09963 P 00000000
N09964 P 00000000
N09965 P 00000000
N09966 P 00000000
N09967 P 00000000
N09968 P 00000000
N09969 P 00000000
N09970 P 00000000
N09971 P 00000000
N09972 P 00000000
N09973 P 00000000
N09974 P 00000000
N09975 P 00000000
N09976 P 00000000
N09977 P 00000000
N09978 P 00000000
N09979 P 00000000
N09980 P 00000000
N09981 P 00000000
N09982 P 00000000
N09983 P 00000000
N09984 P 00000000
N09985 P 00000000
N09986 P 00000000
N09987 P 00000000
N09988 P 00000000
N09989 P 00000000
N09990 P 00000000
N09991 P 00000000
N09992 P 00000000
N09993 P 00000000
N09994 P 00000000
N09995 P 00000000
N09996 P 00000000
N09997 P 00000000
N09998 P 00000000
N12000 P 00000000
N12201 P 0
N12202 P 0
N12203 P 0
N12204 P 0
N12205 P 0
N12206 P 0
N12221 P 0
N12222 P 0
N12223 P 0
N12224 P 0
N12225 P 0
N12226 P 0
N12241 P 0
N12242 P 0
N12243 P 0
N12244 P 0
N12245 P 0
N12246 P 0
N12801 P 0
N12802 P 0
N12803 P 0
N12804 P 0
N12805 P 0
N12806 P 0
N12807 P 0
N12808 P 0
N12809 P 0
N12810 P 0
N12811 P 0
N12812 P 0
N12813 P 0
N12814 P 0
N12815 P 0
N12816 P 0
N12817 P 0
N12818 P 0
N12819 P 0
N12820 P 0
N12841 P 0
N12842 P 0
N12843 P 0
N12844 P 0
N12845 P 0
N12846 P 0
N12847 P 0
N12848 P 0
N12849 P 0
N12850 P 0
N12851 P 0
N12852 P 0
N12853 P 0
N12854 P 0
N12855 P 0
N12856 P 0
N12857 P 0
N12858 P 0
N12859 P 0
N12860 P 0
N12881 P 00000000
N12882 P 00000000
N12883 P 00000000
N12884 P 00000000
N12885 P 00000000
N12886 P 00000000
N12887 P 00000000
N12888 P 00000000
N12889 P 00000000
N12890 P 00000000
N12891 P 00000000
N12892 P 00000000
N12893 P 00000000
N12894 P 00000000
N12895 P 00000000
N12896 P 00000000
N12897 P 00000000
N12898 P 00000000
N12899 P 00000000
N12900 P 00000000
Posted: Fri 16 Oct , 2015 19:35 pm
by jamesgates1000
Thanks Martin. I'll check them tomorrow.
Posted: Wed 28 Oct , 2015 17:31 pm
by jamesgates1000
I have checked to parameters and mostly they are as the list you have given me. Some have been changed as they correspond to backlash but others are harder to decipher.
Do you know where I can find detail of what each numbered parameter refers to?
When the batteries died on the servo drives would I have lost any of the main parameters, I am guessing not.
What would be your suggestion for the next step in debugging the alarm?
Thanks for your help so far.
Posted: Thu 19 Nov , 2015 10:19 am
by jamesgates1000
Wiring all looks good, double checked all the connectors were okay.
I disconnected the motor from the x axis drive and still got the error- thought that this would rule out an issue with the motor.
Then i swapped over the z and x axis drives completely - now the 441 error is on the z axis.
Does this suggest a problem with the servo drive?
If so, does anyone know of a good company that could repair or replace the drive?
Posted: Thu 19 Nov , 2015 11:24 am
It would suggest that.
I presume this a Fanuc drive unit?
You could try,
Pennine Automation Spares
Brookwoods Industrial Estate
Holywell Green Halifax
West Yorkshire
HX4 9BH
England UK
A couple of ex Denford employees had come from their.
Posted: Mon 30 Nov , 2015 9:11 am
by jamesgates1000
Thanks Martin.
I sent the drive to pennine and they have confirmed that it is faulty and a replacement is on its way.
Just wondered if you have the procedure for resetting the absolute encoder position/home position as it was lost when the batteries died.
Are there limit switches? Or some makers marks on the axes that i need to line up?
Posted: Wed 02 Dec , 2015 17:40 pm
by jamesgates1000
It seems that the machine finds its own home position when you home it. Machine now works! Now just got t fill it with coolant and cut something. Thanks for all your help with this.
