Denford cyclone TU150E Threading problem
Hello
I have been trying machining small thread on my cyclone lathe.....Unfortunately it does not work.
[BILLET X38 Z55
G99 G21 G40 G50 S3000
G96 S150 M3
M06 T0101
G00 X39 Z2
G01 X-1 F0.125
G00 X38 Z1
G71 U1.5 R0.5
G71 P1 Q2 U1 W0.1 F0.1225
N1 G00 X16
G1 Z0 F0.1
X20 Z-20
Z-35
G03 X30 Z-40 R5.0
G01 Z-45
X32
X35 Z-46.5
Z-50
N2 X38
G28 U0 W0
M06 T0101
G01 G42 X38 Z1 F03
G70 P1 Q2
G28 G40 U0 W0
G97 M06 T0505 S00
G00 X20.25 Z0
G76 P030060 Q100 R0.05
G76 X18.16 Z-33 P0920 Q250 F1.5
G28 U0 W0
M06 T0101 S1500
G00 X0 Z2
G01 Z-6 F0.1
G00 Z2
G28 U0 W0
M06 T0202 S1200
G00 X0 Z2
G74 R1.0
G74 Z-30 Q10000 R0.0 F0.125
G28 U0 W0
M30
2017-04-08 11.20.09.jpg (422.46 KiB) Viewed 20051 times
Re: Denford cyclone TU150E Threading problem
Can you check that the machine displays the actual spindle speed & that it's close to the requested.
Also line 25 show a spindle speed of S00. I am not a programmer so not sure if it's that.
Martin wrote:Can you check that the machine displays the actual spindle speed & that it's close to the requested.
Hello I checked.... unfortunately the actual spindle speed is not close to the requestet. When I request 400 rpm the machine display 560rpm. Regards
Maybe it´s like on my TU150U, there is a possibility to adjust the "spindle override" on the operator panel which gives a higher or lower speed. In your case it could be possible that it´s set on 140% override.
What's it like at top speed??
Hello
I am adjusting inverter today and working ok. Spindle speed is precise but the threading still not working.
Please help.
Martin wrote:What's it like at top speed??
I set a maximum speed of 3700 rpm
What speed are you asking for in the program when threading?
I would suggest 300 to 400 RPM
Steve wrote:What speed are you asking for in the program when threading?
I tried 300 and 400rpm .... it does not help.
What happens when you program 300 rpm and try and cut the thread? Does it just hang up in program or do you get a message on screen?
If so can you post another photo showing the program and the message?
How did you create the program? What package?
Steve wrote:What happens when you program 300 rpm and try and cut the thread? Does it just hang up in program or do you get a message on screen?
Hello
When I try program 300 rpm the machine stop and i get messege on screen.
I copied the program(g-code) from the user manual for denford starturn pc
And alsow I make short video : https://youtu.be/Wbb0pxW9i5Q
2017-05-20 09.49.37.jpg (227.04 KiB) Viewed 20006 times
What does it say when you click on the details tab.
I will upload th threading program Monday for you to try.
May be the program is the problem.
Steve wrote:What does it say when you click on the details tab.
Hello Steve
When I click on the details tab it does say "The spindle speed is probably too high for the axes to follow"
I will be very grateful if you check this program on your machine. Regards
Hi Dont know if you got this sorted but would say that you have G96 instead of G97
Phil
