Burning smell from R-Type Block
davidfhu
Post by davidfhu » Mon 23 Aug , 2010 16:34 pm
Can anyone explain how come I see smoke from my R-Type Block?
I am using 4 flutes ball nose milling bit at stepover 15% with 23000rpm. What is wrong? With 2 flutes, it is fine.
Best regards,
David Fhu
“Dream as if you'll live forever, live as if you'll die today.” - James Dean
Re: Burning smell from R-Type Block
Post by Denford Admin » Tue 24 Aug , 2010 10:07 am
The machine is not moving quickly enough so the cutting flutes are mostly rubbing against the wood instead of cutting it - causing it to smoke
Either:
Decrease the spindle speed RPM
or
Increase the axis feed (mm/min)
davidfhu
Post by davidfhu » Wed 06 Oct , 2010 2:17 am
Thank you.
Best regards,
David Fhu
