Techsoft 2D Ver 2 to Techsoft 2D Ver 1 conversion procedure
A forum for issues relating to the use of TechSoft 2D design and Denford CNC machines
Post by bradders » Wed 05 Apr , 2006 8:46 am
How do I design in Techsoft 2D Ver 2 and convert to Techsoft 2D Ver 1 so I can output to a Denford Machine Tool via Denfords Techsoft 2D post processor?
N.B. Techsoft said when they brought out Techsoft 2D Ver 2, that there was no need to be able to link directly to the Denfords Techsoft 2D post processor, because the mods, upgrades and embellishments they had incorporated where graphic based and would not be applicable to a machining operation on a machine tool.
Post by bradders » Wed 05 Apr , 2006 8:48 am
You have to have both Techsoft 2D Ver 1 and Ver 2 on your PC
With the design opened in Techsoft 2D Ver 2
Select
FILE
EXPORT
DESIGN TOOLS DRAW V1
This should then give you a design that can be opened in Techsoft 2D Ver 1
Post by Denford Admin » Wed 29 Nov , 2006 12:35 pm
Alternatively,
If you have VR Milling version 5, then save DXF files of the design from Techsoft V2, and then import them into the easy CAM wizard in VR Milling.
see here for some pictures of the CAM import wizard...
viewtopic.php?t=267
