LINE ANGLES
MAX THE MILLER
Hardware/Software: Denford Triac PC. VR Milling 5.51.0.616
LINE ANGLES
Post by MAX THE MILLER » Fri 27 Nov , 2020 14:00 pm
I've been experimenting with the unlicensed version of QuickTURN 2D Design.
If I look at the properties of a line drawn parallel to the X axis its angle is given as 3.54331.
If I look at the properties of a line drawn parallel to the Z axis its angle is given as 7.08661, which is twice the previous figure.
The angles clearly aren't in degrees or radians, so what units are they in? Is there a setting which can be changed to give the angle in degrees?
Thanks.
MAX THE MILLER
Re: LINE ANGLES
Post by MAX THE MILLER » Fri 27 Nov , 2020 14:12 pm
I think I get it.
What the software has done is to take 90 degrees, call it 90 millimetres and convert that to inches.
90mm = 3.54331inches.
Looks clearly wrong to me.
MAX THE MILLER
Re: LINE ANGLES
Post by MAX THE MILLER » Mon 05 Apr , 2021 10:32 am
Does anyone know whether this works correctly in the licenced version?
