I've been experimenting with the unlicensed version of QuickTURN 2D Design.
If I look at the properties of a line drawn parallel to the X axis its angle is given as 3.54331.
If I look at the properties of a line drawn parallel to the Z axis its angle is given as 7.08661, which is twice the previous figure.
The angles clearly aren't in degrees or radians, so what units are they in? Is there a setting which can be changed to give the angle in degrees?
Thanks.
LINE ANGLES
Re: LINE ANGLES
I think I get it.
What the software has done is to take 90 degrees, call it 90 millimetres and convert that to inches.
90mm = 3.54331inches.
Looks clearly wrong to me.
Re: LINE ANGLES
Does anyone know whether this works correctly in the licenced version?
Re: LINE ANGLES
Hi Max. You are correct, the angle in degrees was being converted as though it was from mm to inches. This has now been corrected in the latest version 1.34 which can be downloaded from the website. Having a license or not won't make a difference.
Re: LINE ANGLES
Thanks for that.
I've downloaded the latest version and it works fine.
Max.
Max.
