RouterNS N03915 Spindle motor upgrade. Spindle fails to run
martinfield
Post by martinfield » Tue 21 Mar , 2006 10:32 am
Spindle motor fails to start even though router runs machining sequence, have checked e-switch and SGR relay (relay is solid state?) Has anyone any ideas, many thanks in advance.
Post by Denford Admin » Tue 21 Mar , 2006 10:54 am
This is the spindle/guard interlocking circuit - should help see what is going wrong - could be fuse F1 - could be E Stop button second contact which would stop the door lock solenoid from firing.
After talking to our engineers, they say that the spindle motors have occasionally failed to run, even though they will work if you plug them directly into a 240V AC supply.
The best way to find out if the guard and interlocking is working fine and that the motor is faulty is:
(Be careful :!: :!: )
Unscrew the guard door plunger
Push plunger into the door lock hole (so you can open door and run spindle)
Open the door
Disconnect the router motor "kettle" plug
Connect the software to the machine
Start the spindle (M03)
Put a voltmeter on the router kettle socket and see if there is around 160V DC
(Make sure spindle speed is set to maximum in the software ~ 23000RPM)
If the voltage is OK but still don't get any revs on the motor then you will have to replace the motor (send it back to us)
martinfield
RouterNS Spindle motor
Post by martinfield » Tue 21 Mar , 2006 11:35 am
Many thanks for your quick reply, after re-cleaning the motor brushes the motor is now working! New brushes are in order I think! Do you stock? The spindle is a 'Porter-Cable' Many thanks again.
Post by Steve » Wed 22 Mar , 2006 1:32 am
Is your motor the silver coloured 1.25 KW motor? There are some older machines with a smaller black motor fitted.
You will nead to specify the motor type when you order the brushes.
We will have brushes for both types at the factory. Call 01484 728000 and ask to place a spares order.
Orders under £250 are cash or cheque before delivery.
