v5.27 - Added low air pressure message
v5.27 - fixes to update the datum position if datum wasn't showing in 2D/3D simulation
v5.27 - Updated machine not found dialog
v5.27 - Updated VMC 55xx (not 52xx) mints... mcode is now run in a task so it doesn't freeze all other tasks while waiting for an input
v5.28 - Updates to circle expand makes converting back to arcs more reliable in the DXF import wizard
v5.28 - datum position (eg centre) not being updated unless you had the datum symbol showing - fixed
v5.28 - fixed VMC pro and std 4th axis mints which timed out on Mcodes (to do with mod in 5.27 to run mcodes in a seperate task)
Check here for latest version:
VR Milling v5.28 released 16th June 2009
