Denford Software & Machines
Welcome to the Denford CAD CAM CNC forum
Hint - Try the google search at the bottom of the page
It is currently Sun 27 May , 2018 20:14 pm
Post new topic Reply to topic  [ 2 posts ]
Author Message
 Post subject: Retrofitting Spindle Digital RPM meter to a Viceroy lathe
PostPosted: Thu 09 Apr , 2015 10:36 am
Offline
Location: New Zealand Hardware/Software: Viceroy TDS 1/1GB lathe, Imperial, stripped down and rebuilt.
Hello
I found a Chinese supplier of cheap digital tachometers specifically designed for machine tool applications.
The trigger 1 pulse per revolution and measure the period between pulses. This means good update times even at low rpm.
They are available in red and blue. I fitted a blue one to the Viceroy to match the colour scheme.
I was able to modify an existing bushing on the spindle to fit a trigger magnet. The bushing retains the rotating components on the spindle and is not loaded.
I was able to mount the sensor on a bracket within the headstock.
File comment: The existing bushing modified by potting a magnet in a milled slot. A similar slot was milled on the other side to balance the bushing.
File comment: A heavy duty bracket to hold the sensor.
File comment: The sensor mounted inside the headstock. It is bolted to holes drilled and threaded from outside the headstock.
File comment: A paper/cardboard mock up of the control panel with RPM meter to test ergonomics.
_________________
Dazz
Top
 Profile
 Post subject: Re: Retrofitting Spindle Digital RPM meter to a Viceroy lath
PostPosted: Fri 07 Apr , 2017 12:03 pm
Offline
Here is the finished control panel.
_________________
Dazz
Top
 Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 1 guest
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
Template made by DEVPPL
[ Time : 0.147s | 20 Queries | GZIP : Off ]
Loading
