Denford Software & Machines
Welcome to the Denford CAD CAM CNC forum
Hint - Try the google search at the bottom of the page
It is currently Tue 18 Sep , 2018 21:22 pm
Post new topic Reply to topic  [ 4 posts ]
Author Message
 Post subject: Denford Viceroy TDS 1/1 GBL Chuck Wanted
PostPosted: Tue 24 Jan , 2017 20:59 pm
Offline
Posts: 25 Hardware/Software: Denford Viceroy TDS 1/1 GBL
Hi, I just bought a really nice ex collage TDS 1/1 with hardly any wear, the problem is I am not familiar with this machine and it has come without a chuck, firstly can anyone advise where I might get a chuck for it and what types were fitted to it, as I understand it needs to be 1 1/2 x 8TPI
Top
 Profile
 Post subject: Re: Denford Viceroy TDS 1/1 GBL Chuck Wanted
PostPosted: Tue 24 Jan , 2017 21:27 pm
Offline
You can use any chuck that will fit a backplate. What you need is a back plate. The nose thread is indeed 1.5" 8TPI BSF, which is a 55 degree thread.
You could buy a backplate casting and have someone machine the register and cut a thread in it for you. Once you have the backplate done just buy yourself a suitable chuck to bolt to it.
Top
 Profile
PostPosted: Fri 27 Jan , 2017 12:25 pm
Offline
Location: East Midlands, UK Hardware/Software: 280 VS lathe, Denford Senior E-type mill, Senior Major Universal Mill
I've put a drawing of the thread and register in this thread.
Both the thread size / form and register diameter are apparently the same as Boxfords, and putting "chuck back plate viceroy boxford" into your search engine will show a variety of suppliers.
I've read that the tolerances of some items available can mean you have a sloppy fit at one extreme, or even an interference fit at the other - so it may be worth measuring the diameter of your register and then checking with prospective suppliers what tolerances their are machined-to.
Regarding chucks, there are many to choose from - which I would categorise as follows:
1) Cheap far-eastern (Chinese) imports - quite variable in quality, and can be over heavy with very thick jaws. Often require a complete dis-assembly, de-burr and clean to remove casting sand, grinding dust, etc - then re-assembly with fresh grease.
2) Mid-price eastern European (e.g. 'Bison') - generally better designs and quality 'out of the box'.
3) UK / US manufacture (e.g. Pratt Burnerd) - top notch, will last for ever, but expensive to buy new.
Used examples from categories 2 & 3 can be found (sometimes at very good prices) but beware of abused / worn out examples.
What part of the country are you in? We might be able to point you towards a local reputable supplier.
Top
 Profile
PostPosted: Sun 29 Jan , 2017 15:24 pm
Offline
Hi Andy, thanks for the info, I am in Leicester
Top
 Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 1 guest
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
Template made by DEVPPL
[ Time : 0.155s | 14 Queries | GZIP : Off ]
Loading
