Denford CNC Baruffaldi Lathe Tool Holders
jamesgates1000
Serial number - H00913.
Serial number - 70826B.
Post by jamesgates1000 » Wed 04 Jan , 2017 21:03 pm
I have some tool holders to fit the 8 station Baruffaldi turret on the Cyclone and possibly other machine, made from mild steel and chemical blackened. The bore is left undersize so that it can be trued up in the machine. £28 each delivered. Please not these will NOT fit on a 6 station turret.
Chemi Black.jpg (702.39 KiB) Viewed 4868 times
I also have some ER16 and ER25 Collet Chucks that I have modified to fit in the above holders. £35 each delivered.
Last edited by jamesgates1000 on Sat 18 Mar , 2017 16:16 pm, edited 1 time in total.
Taylormade
Re: Denford CNC Baruffaldi Lathe Tool Holders
Post by Taylormade » Mon 06 Mar , 2017 17:44 pm
"I have some tool holders to fit the Baruffaldi turret on the Cyclone and possibly other machine, made from mild steel and chemical blackened. The bore is left undersize so that it can be trued up in the machine. £28 each delivered."
Hi James,
Do you have an email. Im interested in purchasing 4 of the tool holders from you.
malutki69
Post by malutki69 » Thu 27 Sep , 2018 21:28 pm
Hello
Im interested in purchasing 4 of the tool holders from you. Regards
