LaserCAM and QuickCAM 2D v1.6 released 19th June 2007
Post by Denford Admin » Tue 19 Jun , 2007 16:02 pm
Last edited by Denford Admin on Tue 19 Jun , 2007 17:01 pm, edited 2 times in total.
Post by Denford Admin » Tue 19 Jun , 2007 16:03 pm
Notes on v1.6:
added Quickcam version info into the post output as a comment
more fonts added to the install
fixed the problem where clicking on the select arrow again, would stop you from doing a rectangle select (froze up the select in the cad window)
fixed problems where arcs/circles/rectangles would revert back to original orrientation if grouped, then mirrored
added make/break group to the popup menu
added Plunge Feed Percentage=25 into post processor file to speed up plunging in some machines/materials
fixed open-with file (double clicking an mcm file) which had stopped working
put minimum widths on the toolbars (you could make zero width when floated)
