kokotis
- Hardware/Software: quick turn 2D
denford micro turn pro in schools
Post
by kokotis » Mon 25 Oct , 2021 12:48 pm
Good morning,
as you can see, i try to create a quarter circle with r=10. The problem is that the center of the circle is not right. I has to be (0,-5) and somehow it autocompletes itself in this nonesense. Every time i try to change the center coordinates manually, all the other parametres change randomly. Please help me to do it right !
Thank you in advance.
Image link
https://prnt.sc/1xacfxu
![Image](https://prnt.sc/1xacfxu)
![CNC Guru CNC Guru](./images/ranks/wiz3.gif)
Post
by Steve » Tue 26 Oct , 2021 16:51 pm
The image shown is for Quick Turn 2D not QuickCAM. QuickTurn software works in diameter mode as does the machine. If you have a radius of 10 then the Z position would be -10 but the X value would be 20.
![Capture.JPG](./download/file.php?id=5606&sid=bc315df7ab9ddeac25a339ef54d57e30)
- Capture.JPG (70.66 KiB) Viewed 8860 times
Post
by Steve » Tue 26 Oct , 2021 17:05 pm
I would also note that when using a Microturn you should probably have a maximum component length of 40 and diameter of 25
kokotis
Post
by kokotis » Tue 09 Nov , 2021 12:53 pm
thank you very much Steve !
